new from mo
Old Feb 19, 2012 | 08:47 AM
jerryl's Avatar
new from mo
i live outside st.louis,originally from chicago.bought 69 442 conv in 78 ,one owner car,locked up wheel bearing,for $100.00.repaired and drove till early nineties.car is trophy blue with lgt blue int,air am-fm-8track, disc brakes,tilt,pwr ant rally guages.currently doing complete resto.motor trans brakes wiring done,most body work done,just finished replacing trunk floor.car is numbers matching 400/400 turbo trans.want to add pwr windows,will need advice.
Old Feb 19, 2012 | 09:01 AM
Welcome, back in 1980 I picked up a 57 Chevrolet Belair Convertable that way. Bought for $350, repaired bearing and spindle, and I sold it for $650! Thought I made a killing! If I knew then what I now....!
Pic's are always appreciated!
Old Feb 19, 2012 | 12:04 PM
citcapp's Avatar
Welcome to CO
How about some pictures of your work in progress. We all like to see work as it is being done. They spur the rest of us slackers to get back out in the garage and get to work.
Old Feb 19, 2012 | 12:33 PM
jerryl's Avatar
pics
wil post some pictures when i figure out how to,not well versed in this.by the way,had a 56 starfire conv,and 57 ninety eight with j-2 when much younger.
Old Feb 19, 2012 | 12:43 PM
jerryl's Avatar
will ,when i learn how!!
Old Feb 19, 2012 | 03:38 PM
501Paratrooper's Avatar
Welcome to CO
Old Feb 19, 2012 | 04:40 PM
garys 68's Avatar
Ofallon, MO checking in here. Pics of the project please.
Old Feb 19, 2012 | 04:45 PM
That 442 sounds like it was well optioned, should be a sweetheart when you finish it.
Old Feb 19, 2012 | 07:21 PM
OLD SKL 69's Avatar
GM Enthusiast
Welcome to the forum!
Old Feb 19, 2012 | 07:52 PM
rcorrigan5's Avatar
Randy C.
Welcome to the forum! This is a great place to learn and get advice on what to do, especially if you run into a rough spot. I restored my '68 4-4-2 conv in 2007 and this site helped me out a lot. I still have a '69 to do as well. Perhaps your work will spur me on!
Power windows - if it were me, I'd be inclined not to add them. I don't have them on my '68 and I really don't notice any difference. My '69 does have them and I suspect adding them to a non-pwr window car might really cost some bucks and be labor intensive. I know you will have to drill holes in the back for the rear wire harnesses on each side. Also, finding an original set-up may also be elusive. I don't know anything about after-market pwr window set-ups - perhaps someone else can address that.
Good luck and post some pictures when you can!
Randy C.
Old Feb 20, 2012 | 06:11 AM
jerryl's Avatar
have a cousin in olympia,i have an original set up from a 70,wiring,switches,regulators,motors even boots for doors wondering how or if possible to make them work.
Old Feb 20, 2012 | 06:51 AM
stlbluesbrother's Avatar
Good to see another Olds enthusiast in the St. Louis area - welcome to the forum.
In regard to the power window installation, you can search this site for old project advice, good practices, etc. And, I know of some local guys who have worked on these, as well.
Mike
Old Feb 20, 2012 | 07:14 AM
Bluevista's Avatar
Registered
All convertibles should have power windows.
It makes putting the top down and up so much easier and you won't be tempted to do the hideous leaving the quarter windows up deal with the top down.
Installing original power windows is a lot easier than the aftermarket type, you know they'll fit. It's really no big deal if you get everything you need from the donor car. You should have copies of the factory service manual, the assembly manual, and the Fisher Body manual on hand to guide you through it.
The hardest part is pulling the doors off so you can drill the holes for the wiring boots in the doors and jambs IMO.
I installed original type power windows and locks in my former '71 Vista Cruiser. I never did it before and I had everything in and working in a few days, and with four doors it's twice as much work.
Old Feb 27, 2012 | 09:55 PM
spiderjason's Avatar
Welcome to the forum!!
Old Feb 28, 2012 | 05:51 AM
Oldsguy's Avatar
Past Administrator
Welcome to the site.
Sickle
Aug 31, 2013 08:28 AM
ah64pilot
Sep 19, 2012 10:55 AM
ah64pilot
Aug 17, 2012 02:36 PM
skinny
Apr 23, 2007 02:46 PM
redrumloa
Mar 10, 2007 06:45 PM
