New member Bob in Topeka. 68 cutlass
Old Aug 26, 2014 | 01:11 PM
bob66542's Avatar
I've had this car quite a while, and the clutch is very stiff- and I'm getting older! It appears to me the z-bar moves around a lot, and I know the return spring is incorrect, it streches around the frame! Does anyone have a copy of the factory parts book w/ illustrations showing exactly what parts are used in the z-bar and their correct order/part #s? it was orig. a 350 3 spd but now has a 400 and 4 spd. I've seen rebuild kits that show varying parts and the pic's are not clear enough for me to tell what is a steel washer, what is a felt washer, and what is I think, a nylon cup washer. Thanks in advance for any possible help!
Old Aug 26, 2014 | 01:39 PM
allyolds68's Avatar
www.wildaboutcars.com has the Assembly Manual scanned for the 68. It's free to join
Do a search here. gearheads78 (Richard) and mcalvo (Michael) both did recent 68's with 4 speeds. The universal bushing kits may not fit. The Z-bars for a 70-72 Olds or a Chevelle are not the same geometry as the 68 Olds. I had a 70 Olds Z-bar that was in nicer shape than the 68 one that I had but it didn't fit right.
I had a lot of time to research when I did mine and I bought bushings from McMaster Carr. I think I bought the felt washer and nylon cup washer form Year One. The eye holes at each end of the Z-Bars have a tendency to elongate. I think I built mine up with weld and redrilled them to make them round again
Old Aug 26, 2014 | 01:44 PM
don71's Avatar
same but different
Welcome Bob, hope you can get that figured out and make it better.
Old Aug 26, 2014 | 04:41 PM
Welcome Bob, post some pictures when you get a chance.
Old Aug 28, 2014 | 12:38 PM
bob66542's Avatar
Thanks so much for the link to the assy. manual- the pic is very clear how the innards go. will pull my z bar this wknd and have a look. had my son in law work the clutch while i watched and theres a lot of flexing going on at the bracket end of the z bar.
Old Aug 29, 2014 | 10:04 AM
Joffroi's Avatar
Runner
Welcome from another Kansas member (and 68 owner).
Carshinebob
Jan 18, 2012 10:05 PM
JIM'S w30
Apr 7, 2011 07:42 PM
Cutlass S 455
Jan 13, 2011 06:21 PM
jaunty75
Nov 8, 2010 09:49 AM
Bob Lynch
Jun 16, 2009 09:43 PM
