new guy needs some help
Heelo Guys and Gals,
This may seem like a strange request, but need your help. I bought a Dana rear, yes, its a Dodge rear, 30 years ago. For what ever reason the guy had installed Olds brakes, drums, etc, with aftermarket axles. Well, after all this time I got the car rebuilt and moving. Yes, it is a Dodge, my first car, and couldn't bear to sell it.
The car is allot faster than I ever thought it would be, and the drums are a little scary to me. I cannot find anywhere what type or car they came off of. The drums are 2 piece where the center section has tabs bent over to hold it to the outer section. I am guessing these parts came off of a late 50's or early 60's car. Shoes are 11 x 2 inches on a 5 x 5 bolt pattern. Center register is 3.075.
Question is, am I better off just finding a later backing plate and updating the whole thing or are there some drums out there that will fit this? If so, where would I find these parts?
Thanks for the help, Bill
I know discs are better, but I was trying to avoid spending the money to changeover when all I needed was the drums. Plus would have to change the master cylinder. Didn't want to open that can of worms.
I'll have to check on the size. I did get a drum for a 85 something, at work, don't remember, but the offset was wrong, only about 1/4 of an inch to much. Drum was going to hit the backing plate. Other than that it would work. I will see what the number you gave me does at the parts store compared to what I have.
Thank you, that is what I was trying to find.
Don't get me wrong, the car stops fine, it was the drum and the way it is made that was worrying me. I upgraded the front to discs a long time ago.
Bill
Bill
The drums you have in the picture is the same as the one I got from NAPA. The offset is about a 1/4 inch too much, it will hit the backing plate. If I wanted to just change the backing plate to fit the drums, what years should I be looking for and where in the world would I find them?
Are there allot of years that will interchange and what is easier to find?
Any NOS places around that may have them?
