New to the forum and looking for advice and ideas
Old Jun 8, 2015 | 09:31 PM
Christine72cutlass's Avatar
I am a proud owner of a 1972 olds cutlass supreme and to say the least I am at the first stages of restoration! After much money spent i have my 455 completely rebuilt. While I continue to save for the step I am just joy riding. I am curious if anyone with the same vehicle has installed a retrosound radio and had an issue with the radio sound glitching or skipping only when the car is running? Plays music fine when the ignition is turn back to acc. Any ideas or troubleshooting tips? My grounds seem fine and the only other thing I have done is take the constant and ignition wires and connect them together and directly to the battery. Same outcome.
Old Jun 8, 2015 | 11:13 PM
rustyroger's Avatar
'87 Delta 88 Royale
Is it momentarily cutting out or are you talking about cd's skipping?.
Either way I think the fault lies in the radio, possibly a broken wire that only becomes apparent with the vibration from running the engine.
At first glance at your post I thought you were talking about interference from the ignition or charging system, but that would be a constant humming or crackling with the engine running.
Roger.
Old Jun 9, 2015 | 04:39 AM
Welcome to the site, post some pictures of your car when you get a chance. As far as your radio, if you truly are connected to the battery, you've eliminated the chances of any power disruptions.
Old Jun 9, 2015 | 06:46 AM
jaunty75's Avatar
Christine72cutlass
First question. Is this your username because your name is Christine? Or is it because your car behaves like the car in the Stephen King novel of the same name?
Sounds like poltergeists. I'm guessing the latter of the two possible reasons above for your username.
Old Jun 9, 2015 | 07:31 AM
I definitely nicknames it Christine based on the movie. My name is shawn and I will be trying to post some pictures of the car sometime here in the near future. -Rustyroger- the source of the music I was playing was both through a Bluetooth connecting as well as the radio. But yes it is momentarily cutting out and it is in pretty consistent intervals...plays 1 sec cuts out 1 sec. I am contact with Retrosound now and hopefully they can give me more ideas specific to their radio. I thought that maybe it has something to do with the amount of voltage coming from the alternator. I read somewhere about a phi filter? or something that acts as a capacitor to keep a continuous current to the radio.
Old Jun 9, 2015 | 07:46 AM
I would double check for bad connections, power, ground and splice joints.
Old Jun 10, 2015 | 12:53 AM
rustyroger's Avatar
'87 Delta 88 Royale
My Nissan Micra dd has the same issue, basically because it has a cheap radio and an old aeriel (antenna to you guys ).
The radio seeks the best signal strength, and if it decides it's too weak it will cut in and out, particularly surrounded by high buildings or any place with not so great reception.
Does the cd or bluetooth play pre-recorded music well?.
If so then you may have a bad antenna or just not a good radio.
Roger.
Old Jun 10, 2015 | 06:08 AM
jaunty75's Avatar
Originally Posted by rustyroger
an old aeriel (antenna to you guys).
Thanks for that clarification. To us, aerial (Ariel) is a mermaid.
Cutty77
Jul 7, 2015 01:34 AM
Badbirds
Mar 30, 2015 09:53 AM
68Saffron442
Oct 3, 2014 06:23 PM
71 sienna supreme
Wheels and Tires
Aug 3, 2011 08:26 AM
