New to the Forum.
Old Jun 1, 2009 | 03:04 PM
Reaper's Avatar
New to the Forum.
Hey guys, new here, my name is Dave. I got an 85 cutlass salon with a 400 small block 30 over, 10:1 compression, flat top pistons and low range cam. with a 700r4, shift kit and 2500 stall.
Old Jun 1, 2009 | 04:16 PM
gearheads78's Avatar
car guy
Welcome.....I'll try to protect you from pitch forks and burning torches as long as I can.
Old Jun 1, 2009 | 05:30 PM
citcapp's Avatar
Welcome to the site Reaper I hope your not grim, nice sounding ride. Great bunch of guys here
Old Jun 2, 2009 | 04:19 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO. Sounds like your car is a fast one. Where did you get the 400 from? Did you do the conversion yourself?
Old Jun 2, 2009 | 04:23 AM
Welcome
Welcome aboard
Where ya'll from?
OOOOOOOOOOOOPS never mind, Indiana. Gottcha
Old Jun 8, 2009 | 02:16 PM
Reaper's Avatar
Thanks guys.
To answer your question I had a machine shop build the motor and a mechanic weld the motor mounts. This was the first time I ever swapped a motor and trans but it went pretty smooth.
It still has the 7.5 factory rear end, I haven't found any thing that will fit a g body at the junkyards since a lot of 80's and older have been crushed.
Old Jun 8, 2009 | 02:20 PM
Oldsguy's Avatar
Past Administrator
Talk to "Monzaz" for info on rear ends that fit into the G body.
Old Jun 8, 2009 | 02:58 PM
car guy
The easiest rought is a 8.5"out of a Grand National or G-body 442. Its a bolt in deal. If not just do a 9". I pieced one together for my old 78 Malibu pretty reasonable. You can make a 12 Bolt Chevelle rear work too but requires some work to the mounting angles. For what they want for 12 bolts these days just be done with it with the 9"
BTH my 7.5" lated 6 passes with my mild 406 so you are on borrowed time.
Old Jun 8, 2009 | 05:28 PM
82 Grocery Getter's Avatar
Welcome Dave! Anxious to see a pic!
67 Olds 442
Mar 27, 2012 08:57 AM
Baugher Garage
Oct 2, 2011 06:30 PM
bobbarry
Sep 10, 2009 11:10 AM
skinny
Apr 23, 2007 02:46 PM
