New car. been sitting.
I just bought a 67 delta 88 4 door hardtop. Its been in a barn for a while but with regular starts. I know I need to change the oil, brake fluid, and flush the radiator. Is there anything major I'm missing? Maybe dump the gas too?
Welcome to CO
Yes dump the gas if it is old, change the gas filter as well. Would not hurt to flush out the brake lines and master cylinder and install new brake fluid as well. Don't forget the radiator, drain, flush and install new coolant too.
http://cgi.ebay.com/ebaymotors/ws/eB...ht_11862wt_958
heres the link. you guys can tell me how I did.
yeah I agree. But the interior door panel looked fine so hopefully thats a good sign. I'll give it a good once over once I get it. I might be in the market for door skins or doors if anyone knows a source.
I have a '67 Delta 88 convertible which I've had for just over a year now. If you have questions once you get yours, ask. For example, I can tell more than you would ever want to know about replacing the fuel tank sending unit. I've also rebuilt the carburetor (mine's a 2-barrel), replaced all the shocks, and redid the brakes, including new wheel cylinders, on all four wheels. It still needs lots of things, including a paint job, but one thing at a time. It's quite driveable as is, and I've been enjoying it. The top's been down since about the beginning of May.
You can have a look at it here:
http://picasaweb.google.com/10794548...eat=directlink
Yes, those are aftermarket seat belts in the front. When I got the car, there were no rear seat belts (they had been cut out) and only the outboard front belts. I bought some period-correct belts for the rear off of ebay, but I went with new, aftermarket for the front. I know they're not correct. Sue me. They were a hell of a lot cheaper, they look great, and they work fine.
Car Sitting
You will certainly have to rebuild the carburetor. The gas has probably turned to varnish coating the inside of the carb.
Mike
Mike's Carburetor Parts
Mike
I would doubt it given the degree to which the doors extend rearward on a four-door compared to a two-door. In other words, the doors on two-doors are not twice as long as doors on four-doors. But I'm not an expert!
I would suggest that you change the fluid and filter on the tranny. The 68 Delmont I have started spitting transmission fluid out of the fill tube, got on the manifold and almost caused a fire. The problem was a stopped up transmission filter.
thanks. I'll add that to the list.
1 change oil
1.1 new fuel
1.2 new fuel filter
2 flush radiator
3 service brakes (not sure what it needs yet)
4 new brake fluid
5 new transmission fluid
6 new air filter?
1 change oil
1.1 new fuel
1.2 new fuel filter
2 flush radiator
4 new brake fluid
6 new air filter?
great find takes some sick folks to like the front ends on these cars.my friends thought it was horrible i like it for some odd reason lol. you just have to be a bit different . think you will be very happy with it when you get to go for a drive don't forget to change the trans fluid and filter
Nice buy -almost pocket money
Interested to see the cartage costs in the states --Thought they were very high .then again its a large piece o dirt
mike
TheBigBlueBoat
December 18th, 2014 07:50 AM
mryoung4815
August 19th, 2011 11:51 AM
