new 62' F-85 owner
Old Jul 5, 2012 | 01:35 PM
beachmont's Avatar
new 62' F-85 owner
Just bought a 62' F - 85... Completely unfamiliar with the 215 - any points I should start at?
My engine runs (albeit rough) and has the original air cleaner still in it!
Old Jul 5, 2012 | 01:53 PM
jensenracing77's Avatar
Welcome to CO. i am also new to the 215 V8. i am picking up my block and rotating assembly from the machine shop tomorrow. the biggest thing i know is you need to keep it cool. you should have the radiator checked out and the cooling system flushed. other than that, i would just give it a major tune up and see what you have. if it sit for a long time, i would clean the tank and add fresh gas.
can you post some pictures.
Old Jul 5, 2012 | 01:59 PM
beachmont's Avatar
at the moment this is what i have. i'll post more as they come.
Old Jul 5, 2012 | 02:00 PM
Thats a nice car! I would start with the tuneup, and press on from there.
Old Jul 5, 2012 | 03:28 PM
lol, i bet you have red interior also. my wife and I were looking for a 62 F-85 cutlass for about 8 months and it had to have red interior. after 8 months we found what we wanted. now that we got ours, i see them with red interior all the time.
your car looks real nice.
Old Jul 5, 2012 | 03:32 PM
beachmont's Avatar
see / hear it run here: http://www.youtube.com/watch?v=-JdL4cQc8L4&feature=plcp
Old Jul 5, 2012 | 03:35 PM
beachmont's Avatar
it most certainly does have the red interior / floor shift. Bringing it to the shop in a day or two to have new front floor pans put in.
Do you know anything about where to get parts for this engine?
Old Jul 5, 2012 | 03:41 PM
parts are not a problem. call this guy. he has everything you will ever need. and cheaper than anywhere else also.
http://www.aluminumv8.com/index.htm
Old Jul 5, 2012 | 07:11 PM
beachmont's Avatar
Cool
here are some more shots. it's in pretty good shape, all things considered. can't wait to get the new floors in the front. tired of feeling like fred flintstone.
Old Jul 5, 2012 | 07:28 PM
citcapp's Avatar
Welcome to CO
The F-85 just has to be red no other color looks as good and the white top is just right. Looks like strawberry shortcake with whip cream. Sounds like she needs a tune up and new plug wires to me
Old Jul 5, 2012 | 07:38 PM
64Rocket's Avatar
A good tune up, convert to "Pertronix" ignition, and new plug wires, should be near the top of the list.
Car looks great.
Gene
Old Jul 7, 2012 | 09:06 AM
beachmont's Avatar
hey,
do you guys know what this is / should it be tightly attached? Trying to get this thing running a bit better.
Old Jul 7, 2012 | 09:13 AM
i have a differant set up than you do but i am pretty sure that is just a crankcase vent that goes down to the bottom of the car. i would put a new hose on it to keep it from leaking at the valve cover instead of going to the ground.
Old Jul 7, 2012 | 09:27 AM
beachmont's Avatar
it's a metal tube.
what have you been using for plugs / wires?
Old Jul 7, 2012 | 10:41 AM
rocketraider's Avatar
Oldsdruid
Spec calls for AC 45FF or 46FFS for the aluminum engine. Not sure what currently crosses to that, but the guy Eric referred you to as well as the Rover crowd will know. The 215 and derivatives were used in English Rovers for decades and they turned that engine into what it should have been all along.
One thing I will caution on- the aluminum engine can be picky about antifreeze. Years back there was a factory bulletin specifically stating not to use Peak brand antifreeze in them. I wouldn't use any extended life i.e. DexCool coolant in it (or anything else) either. A good quality green ethylene glycol coolant should work fine in it.
blunosr68
Apr 23, 2019 06:15 PM
lmetcalf
May 31, 2012 06:23 PM
raincitymarc
Feb 23, 2008 08:50 PM
jrblanke
Jan 27, 2008 10:12 AM
redrumloa
Mar 10, 2007 06:45 PM
