navvet
Old Nov 14, 2010 | 12:55 PM
navvet's Avatar
navvet
Hello from a 64 dynamic 88 owner.
I am not sure if this is the right place to introduce myself but I will give it a shot. I have a 64 dynamic 88 with 89K original documented miles. I am the second owner. Interior is great and engine is good. Most of body is in great shape with the only issues being the rear quarter panels.
I have had it for two years and have done the basics to date i.e. radiator,water pump,added duel exhaust, new engine gaskets and hoses and refinished valve covers,oil change and basic tune-up.
Do have starter issues but I will get to that at another forum.
thanks and look forward to replies.
Old Nov 14, 2010 | 03:50 PM
442_Mustang's Avatar
Any Pics???
Old Nov 14, 2010 | 04:08 PM
olds425's Avatar
Welcome to the site. Any pics?
Old Nov 14, 2010 | 04:58 PM
navvet's Avatar
Glad for the response. I am having my other computer repaired...it does a better job of downloading photos. Quick question, I put a rebuilt starter in the 88 and a new ignition key lockset. When I go to start car the engine turns over the starter engages but car won't start and when I turn key to the "off" position the starter keeps running. I have to disconnect the battery using the quick disconnect to stop everything. I then repeat the process about a half dozen times until car finally starts. Once car gets warm I never have this issue.
So what do you think for cause?
citcapp's Avatar
Talking Welcome to CO
Glad to have you on board. X2 on the pictures
Old Nov 15, 2010 | 05:32 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO. I think you might have two problems. The first would be a faulty starter solenoid that will not dis-engage, the second would be incorrect choke setting on the carb. I assume you have pumped the carburetor sufficiently to approach flooding it to the point that it will eventually start.
Old Nov 15, 2010 | 07:51 AM
navvet's Avatar
The solenoid was replaced when the starter was rebuilt. I originally replaced starter and solenoid due to corrision not due to poor starting. I know I have carb issues and a bad fuel pump. If I spray in starter fluid the engine kicks over fine. So I will take your ideas and focus on rebuilding the carb and fuel pump. Appreciate the response.
Old Nov 15, 2010 | 08:19 AM
Welcome
Welcome aboard
Glad you decided to join us.
Old Nov 15, 2010 | 12:44 PM
navvet's Avatar
I am looking forward to this helpful group. I now have a two car garage just for my 88 and I have heat for the winter. Planning on pulling two doors and redoing the interior on those doors. I us U.S.A Parts Supply LTD for a great deal of my parts.... nice inventory.
Old Nov 17, 2010 | 01:20 AM
Wasted's Avatar
Whoops should have looked here before I responed to your pm. Anyways glad to see you figured things out.
