Muncie 4 speed
Old May 16, 2014 | 05:53 PM
72blue442's Avatar
Cool Muncie 4 speed
anyone know what the electric wire connection is for on my 72 4-speed,
It's located just below the clutch fork??
Old May 16, 2014 | 05:59 PM
66400's Avatar
Clutch safety switch, starter won't engage unless clutch pedal is depressed.
Henry
Old May 16, 2014 | 07:10 PM
jensenracing77's Avatar
Welcome to CO. That is the TCS switch. When it is all hooked up and working it would have a wire run to the TCS solenoid. This system only allows the vacuum advance to work in high gear.
TCS = Transmission Controlled Spark
Old May 17, 2014 | 08:00 AM
Henry
Nope, sorry. The clutch safety switch is on the clutch pedal. As noted above, this is the fourth gear switch for the Transmission Controlled Spark system. TCS was an early emissions control system that disabled vacuum advance in all gears except high to reduce NOx emissions.
fast67vellen2o
Dec 28, 2010 11:32 AM
fast67vellen2o
Dec 3, 2010 11:13 AM
joealexander1234
22
Oct 14, 2010 09:13 AM
fast67vellen2o
Oct 4, 2010 11:02 AM
fast67vellen2o
Sep 27, 2010 12:18 PM
