Milodon Oil Pan Touching back of Crossmember
Old Jan 21, 2018 | 04:52 PM
Cody Monroe's Avatar
I am having an issue with my 66 442, I am sitting the motor and tranny in a rolling chassis,Original frame, Original 400 BB 4spd. original MM brackets on the frame new 2261 motor mounts, new tranny mount, but I do have a Milodon 7 qt. oil pan.https://www.summitracing.com/parts/m...bile/model/442 that is made for my car. I am barely touching my oil pan on the backside of the cross member on the passenger side, but plenty of room on the drivers side. any suggestions would help Thanks
Passenger
Driver
Old Jan 22, 2018 | 07:25 AM
Have you verified that the crank is centered in the frame? Try measuring from the center of the crank snout to fixed points on either side of the frame. Unfortunately it's impossible to know how accurately an aftermarket part is made. There is clearance in all the bolt holes for the frame pads to the crossmember, as well as the holes between the motor mount and frame pad. If nothing else, you can loosen all those fasteners and try to jockey the motor sideways a little.
FYI, it's not necessary nor in your best interest to post the same question in multiple forums or even multiple threads in the same forum. You'll get a better answer more quickly if all responses are kept in a single thread so people can read what's been posted previously.
Old Jan 22, 2018 | 04:06 PM
Thank you Joe, I will definitely try that. I did measure and it is off, now I am wondering if my frame is bent.
Did not mean to post twice, was just actually comparing my problems to the other guy. I will post back and let you know what happenThanks again
Cody Monroe
Old Jan 22, 2018 | 04:56 PM
Gary M's Avatar
Did you take the car apart and now found this or is it a frame you just got? Someone on here may have a drawing with measurements to check the frame for straightness. I've seen one for a 72. You could measure to rule out the frame then. You may be able to google it if no one offers one. Good luck.
Old Jan 22, 2018 | 06:38 PM
Yes I took it apart as frame off project. Going back in with original motor, only Change is the oil pan. New motor mounts. That would be cool if I could come up with those measurements. Thanks Gary
Old Jan 22, 2018 | 07:36 PM
Gary M's Avatar
Try what Joe said. Loosen the bolts he mentioned and jockey the motor around. The 7 quart pan may be bigger but it seems like it would look obviously misshapen to be over that far to one side.
VinMichael
Apr 12, 2017 07:25 AM
442KoneKilr
Jan 13, 2016 09:46 AM
speck1148
Sep 9, 2015 10:46 AM
speck1148
Jul 17, 2015 11:18 AM
70cutty
Jun 24, 2015 03:29 AM
