Michael and his 1935 Coupé
Old Feb 22, 2019 | 04:51 AM
hgc.micha's Avatar
Hello, my name is Michael and I have been screwing around with US classics for many years. Currently I am restoring a 1935 F35 Coupe with 3 windows and suicide doors. I'm thinking about replacing the original engine with a 257 in-line eight cylinder, does anyone know more about the High Compression lettering on the cylinder head? Greetings Michael
Old Feb 22, 2019 | 06:27 AM
Michael, that's an AWESOME project. Definitely bad@$$!
Old Feb 22, 2019 | 06:29 AM
Welcome aboard
Cool project
Old Feb 22, 2019 | 07:22 AM
Charlie Jones's Avatar
Phantom Phixer
The F-35 has a six cylinder engine . Putting an in line eight cylinder engine would be next to impossible . The eight cylinder cars ( L-35 ) were slightly longer . 121 " wheelbase , compared to the F-35's 115 ".
The difference in length was in the distance from the cowl to the front crossmember where the radiator is and where the engine front mount is .
The frames . hoods , hood side panels , and front fenders are all different .
A better choice would be a 257 cu. in six cylinder engine from a '49 or '50 Oldsmobile "76" .
Old Feb 22, 2019 | 07:30 AM
CRUZN 66's Avatar
Olds Fever
Welcome to the group... Definitely a cool project vehicle...
Old Feb 22, 2019 | 07:46 AM
Welcome to the site, awesome project.
Old Feb 22, 2019 | 10:36 AM
redoldsman's Avatar
Proud Viet Nam Veteran
Welcome and that is going to be a neat car. A lot of guys would be making that into a street rod and it would make a great one. Glad you are saving it. Charlie Jones gave you some good advice. The 49-50 engine is a big improvement over the one you have. One of the biggest improvements is the later engine has inserts (rod bearings) instead of poured babbit rods. I had a former acquittance that put a 49 engine in his 31 couple and there were a couple of modifications he had to make but i don't remember what they were. He as very happy with the result. The biggest problem will be finding that 49-59 engine that is rebuildable. Good luck and keep us posted.
Old Feb 22, 2019 | 01:05 PM
Phantom Phixer
According to my 1941 Olds parts catalog , all 1933 and up Oldsmobiles had insert bearings .
And , '28 thru '32 six cylinder Olds could be converted to insert bearings by using F33 or F34 rods .
Just something for future reference .
Old Feb 22, 2019 | 01:35 PM
garykrig's Avatar
That F35 engine is a great running engine with plenty of power. I don't see a later six being that big of an improvement. I have owned a F35 sport coupe for 45 years the biggest performance improvement I would like to make is an overdrive. They are geared so low [something like 4:55] they are really humming at 60 MPH.
Old Feb 22, 2019 | 02:40 PM
Phantom Phixer
According to the numbers on the head , this engine came from a 1948 Oldsmobile "98" .
After WWII , "premium" fuels were coming in to vogue . Oldsmobile took advantage of that by offering a " high compression "
cylinder head in some models . This head gave greater power AND economy , over the "standard " head when used with premium .
BTW , the head was cast just after midnight on April 16th , 1948 .
Old Feb 22, 2019 | 03:39 PM
redoldsman's Avatar
Charlie I had read somewhere (probably an erroneous post) that Olds started using inserts in 1937. I guess it is a moot point since the OP has a 1948 engine already.
Old Feb 22, 2019 | 04:03 PM
Phantom Phixer
Actually , there MIGHT be a way to do this . This is only theoretical , so please check and measure before actually attempting this , or even purchasing parts to do it .
A '37 or '38 Olds (or Pontiac ) rear axle would have to be installed . This may very well involve moving or even swapping the spring pads on the housing .
Then a 1940 thru '47 rear end center section (chunk) from a " Hydra - Matic " car would have to be installed in the '37 or '38 axle . These came in ratios as " high " as 3.42 to 1. and they drop right in . 1948 thru '56 rear center sections will also fit a '37 or '38 axle with minor modifications such as grinding the housing somewhat to get the ring gear in and using studs with two different sizes on each end to fasten the center to the housing .
I actually did this on a 1937 Pontiac and put a '54 Pontiac Hydra - Matic (3.23) center in it .
It was a little slower accelerating , but it would cruise easily at 65 MPH .
Old Feb 22, 2019 | 11:53 PM
hgc.micha's Avatar
Thank you very much for your greetings and helpful information. The original engine from 1935 is still in the car. The row eight from 1948 is in my garage.
Old Feb 23, 2019 | 04:49 AM
Bfg's Avatar
Bfg
What's wrong with the original motor?
Brad Chapin
Jul 30, 2019 12:42 PM
senginc
Jun 2, 2019 07:25 AM
68vert
Jul 21, 2015 07:51 PM
kds 69 442
Brakes/Hydraulic Systems
Oct 23, 2013 02:40 PM
Mr Shifty Sidney
Jun 12, 2013 12:06 AM
