matching frame vin to car 72 cutlass s
I need some info or link to match frame vin to car 1972 cutlass s. heres the car vin. 3g87h2r115992 . the frame vin is 6263667 S 366 then below that is 7 22 n then a notch c r .
There is a good post about it with pictures by 2blu442 but i can not find it.
Here you go. VIN stampings on frame
you match the VIN derivative on the frame to the same VIN derivative on the engine block. Do you know how to identify the derivative component? It's there in that link I posted earlier. VIN derivative is based on the actual VIN of the car.
For your particular car, the matching VIN derivative on the block, trans, and frame would be 32R115992.
Derivate component i guess not . Plus i dont have the engine .
One more time. The VIN derivative on the frame will be NINE characters long, and unless the frame came from a Canadian-built car, the third character will be a letter. Nothing you've posted has that form, so nothing you've posted is the frame VIN derivative. Keep looking.
Joe, All 69-72 frames I seen (dozens of them) are on the side close to the top. I don't know about 68 but I think it is 67 and older that it is on the top side.
Your VIN is 3g87h2r115992
So the VIN derivative is 32R115992 (as Joe already mentioned). What does this mean? I'll break it down for you 2 ways.
The VIN 3g87h2r115992 is broken down as
3 - Oldsmobile
G - Model - Cutlass S
87 - Body Style - 2 door hardtop coupe (also called Holiday Coupe)
H - Engine code - 350 2bbl 160 hp V8
2 - 1972 model production
R - Arlington TX production
115992 - Build sequence at Arlington TX Assembly line
The VIN derivative 32R115992 simply matches the engine/trans/frame to the original build. It means this:
3 - Oldsmobile
R - Arlington TX Assembly
115992 - production sequence to match car build.
This is basic Oldsmobile rocket science 101.
You're going to find lots of other parts that are period correct with CFD numbers, or stampings that match production, but won't have VIN #'s on them either.
Johnd
November 28th, 2013 08:31 AM
shockrebuild
February 22nd, 2010 10:09 AM
