manual brakes issues
I took the power brake off my car and replaced master cylinder and rear wheel cylinders. I looked up all the parts for a 71 with manual brakes. Now the pedal is hard and the car will not stop in no matter how hard I apply brakes. The car stopped great before. The reason I took the booster off is the motor setup I am running. no vacuum. Any suggestions.
There should be another hole in the brake pedal arm above the one you are using .
Mount the push rod end in the upper hole . It gives you more leverage to make up for lack of power assist .
Make sure the pedal is properly adjusted according to the CSM .
Cstoliker1
Brakes/Hydraulic Systems
15
April 24th, 2016 11:53 PM
rmsikorski66
September 2nd, 2013 12:52 PM
1969cutlazz
29
December 31st, 2012 05:22 PM
