Long time reader First time contributer
Old May 9, 2018 | 03:48 PM
67CSConvert455's Avatar
Do Damage
Long time reader First time contributor
Every time I Google questions in regards to my 67 Cutlass Supreme Convertible it leads me to threads from Classic Oldsmobile. The information from this website has helped my project tremendously. Currently doing a complete chassis and drivetrain rebuild with the addition of OEM factory options included. My goal is to keep the car looking stock but add modern upgrades, the proverbial ‘wolf in sheeps clothing’.
Old May 9, 2018 | 04:05 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Welcome and nice car. As you have become aware, most everything you need you will be able to find here. Tell us a little more about yourself and what part of the country you are in.
Welcome, most of us found this site the same way.
Old May 9, 2018 | 05:39 PM
Do Damage
We are located in the San Francisco Bay Area. Factory aquamarine black on black combo. It came with bucket seats but changed to bench to fit the family+1. It’s a father sons & daughter project that has been on jack stands for almost two years now.
Old Jun 20, 2018 | 03:50 PM
Do Damage
Buttoning up the suspension upgrades and getting ready for the
engine. Replaced old body bushings with polys and went with
Johnny Joints for the rear suspension. Up front are tubular control
arms and Savitski chassis brace. 17” billet SSI with Pirelli tires.
Global West stiffer rate springs on all four corners 1” fronts .5” rear.
QA-1 single adjustable front and Edelbrock rear shocks.
Can’t wait to get her back on the road.
SPC upper control arms. Four wheel disc brakes. AGR quick ratio steering box.
In the mock up stage for brake lines to rear discs.
Chassis mount rear sway bar.
T/A diff cover to re-enforce the Powertrax & 3:55’s
Old Oct 7, 2018 | 10:10 PM
Do Damage
Replaced the rear Edelbrock shocks with QA1 shocks. Now have single adjustable shocks on all four corners. The rears came with a lower bracket that splays it out a little more and turns the adjustment dial rearward for easier access. I bought them from a racer and he fabricated the brackets.
On the lowest setting the rear was easy to push up and down. Five clicks on both shocks and the rear stiffened up a lot, have a total of nine.
The body is a little fatter so the access holes in the tubular lower arms had to be widened. The poly lower spring pad was shaved to fit the adjust dial.
Old Oct 8, 2018 | 10:54 AM
dmacalli's Avatar
Welcome... Fellow Newbie here as well. Certainly found it it the same way, through "ask the google"
Old Oct 8, 2018 | 01:38 PM
Very nice, should handle really well!! Nice!
Old Nov 21, 2018 | 04:43 PM
Do Damage
Well can’t leave well enough alone. Have to take the front and rear suspension apart again to add these little beauties. Global West came out with some new steering arms and Umi has these slick RLCA brackets. I like the ability to adjust components for my needs. Does anyone have any experience with these?
These are reported to take an average of 0.10 of a second off sixty foot times. Part #4012
The angle of the tie rod attachment hole. These knuckles are supposed to help with bump steer on lowered vehicles with after market upper control arms.
The length is 1/2” shorter than original to speed up steering response. Part# SS-6472GSKB
Ikesgotav8
Feb 1, 2025 06:23 PM
Darwin cotton
Jun 18, 2018 03:10 PM
RockinRoller
Jun 25, 2016 07:14 AM
Tungsten
Nov 22, 2012 09:29 AM
jason
Jun 20, 2012 12:48 PM
