Locked Tailgate in Cutlass Cruiser 1990
How do I unlock my tailgate? I am puzzled by my tailgate which I inadvertently locked while the tailgate was open. As a dummy, I clicked the latch in the lock mechanism closed, while the tailgate was open. Now I cannot reverse the move to truly lock the tailgate. How do I unlock this latch?
Normally, the "bearclaw" part of the latch rotates around the striker when the tailgate (or door) is closed. A spring in the latch assembly assists the bearclaw to rotate to the closed position. As you lift the handle and open the tailgate, the motion of the tailgate moves the bearclaw to the open position and the spring goes over center to hold it in the open position.
If the bearclaw gets rotated to the locked position without capturing the striker, there is no force that will move it to the open position when you lift the handle. You need to hold the handle in the open position and manually rotate the bearclaw to the open position using a screwdriver or similar tool.
1990 Locked Tailgate. Got it! It worked!
Joe, thanks very much. Your explanation was exactly described, and I was able to activate the bear claw as you suggested. The tailgate is now operational again. Much obliged!
Phil Brown
1990 Cutlass Cruiser
Phil Brown
Funkwagon455
Vista Cruiser & Wagons
Nov 23, 2016 07:02 PM
vistacruiser1971
Aug 6, 2012 05:10 PM
