Just joined with 63 F-85 and a 2003 LR Discovery
Old May 21, 2021 | 06:33 AM
BuckeyeF-85's Avatar
Good morning all!
I just signed up this morning. I have a 1963 Olds that was my my moms car ( drove it a bit in high school). it has been in my garage for 30 years. I was always intimidated by what it would take to get it going. Since then I have had a 1999 and now a 2003 Land Rover Discovery. Land Rovers motto of "Making Mechanics out of owners for years" is me. I have replaced the 4.6 (bad bottom end) in the 03 with the 4.0 from the 99. I have totally rebuilt the top end of the 4.0. So now I think I am ready to dive into the Olds. Looking forward to solid advice and encouragement.
Rick
Old May 21, 2021 | 06:50 AM
Originally Posted by BuckeyeF-85
Good morning all!
Rick
Welcome. If you still have the 4.6, build it to go in your 63. It's pretty much a bolt-in.
Old May 21, 2021 | 06:57 AM
Thumbs up
I would hope I could keep the 215 running for a while. It only has 33K miles on it.
The 4.6 is a junk motor in the LR world. Lots pull them at the first sign of trouble and replace with the earlier 4.0
Old May 21, 2021 | 07:01 AM
Cross-bolted mains in the 4.6 block make for a nice build. Buick 300 crank, new sleeves with Chevy 305 pistons, and you get a 298 replacement for the 215. 275-300 HP is doable. Dress it to look like the 215 and no one will ever know.
Old May 21, 2021 | 07:11 AM
35tac's Avatar
Welcome. Lots of help here. Love to see pictures of the 63.
Wayne
Old May 21, 2021 | 07:18 AM
Wayne
Thank you!
Old May 21, 2021 | 10:15 AM
jensenracing77's Avatar
Welcome! Lots of 61-63 Cutlass and F-85 starting to surface. Lots of help and advice available for them now. Post some pictures when you can.
Old May 21, 2021 | 12:59 PM
patshotrods's Avatar
Pat
Welcome Rick! I have a "1963 Oldsmobile F-85 Deluxe".
Old May 21, 2021 | 02:19 PM
Welcome to the site, lets see it.
Old Sep 16, 2021 | 06:39 AM
Do you think anyone would have interest in the 4.6? I wouldn't want much for it
Also, when I figure out how to post pics, I sure will
Old Sep 16, 2021 | 06:41 AM
Just a beauty! Mine is a 2 door. Light blue but you can barely tell anymore because it sat outside in the sun for so many years
Old Sep 16, 2021 | 06:44 AM
Where are you located?
Old Mar 8, 2023 | 08:14 AM
Sorry for the delay Joe
I'm in Central Ohio
Old Mar 8, 2023 | 08:40 AM
Tj Pal's Avatar
Welcome! Sounds like a pretty nice car to start with. pics?
Old Mar 8, 2023 | 01:15 PM
Old Mar 8, 2023 | 03:41 PM
True three on the tree. Nice. I dig the rocket sticker on the valve cover. Do you have any exterior pictures?
Old Mar 8, 2023 | 04:11 PM
Rallye469's Avatar
Looks like a slick car!
I WILL own a ‘63 before I die!
(anyone know how difficult it is to stab a 455 in?)
Old Mar 8, 2023 | 04:41 PM
It can be done, but why? The aluminum V8 weighs 320 lbs dripping wet. The 455 more that doubles that. Add the weight of the trans, bigger rear, bigger brakes to stop it, beefed suspension to support it, bigger radiator (and lots of metalwork to fit it) and you've turned a 2700 lb car into a 64-65 A-body (and I think you already have one of those). On the other hand, go with a Rover block and Buick 300 crank and you get 298 cu in with no increase in weight. 300 HP is my goal with that combo, and in a 2700 lb car that's better power-to-weight than a 1970 W30.
Old Mar 9, 2023 | 03:32 AM
Rallye469's Avatar
Ugh…
You and your logic!
Do you think the rest of the drivetrain could handle the 298?
Old Mar 9, 2023 | 03:35 AM
Ugh…
You and your logic!
I'm planning on using a WC T5. I wouldn't use a Roto5. The rear end is marginal, but frankly if the tires break away before the rear breaks, that's your mechanical "fuse".
I'll add that I've toyed with a few other options for swaps. An Aurora (well, Northstar) would be cool, but since CHRFab shut down some years ago, the RWD conversion parts are unobtanium (and good luck finding a factory RWD N*). Add to that the tremendous width of the DOHC heads that likely will require engine bay mods. The crate motor turbo 4 cyl that GM sells today fits nicely and makes 295 HP, but the whole electronics and 4cyl thing just doesn't do it for me. The small block Buick is just a tall-deck 215 and even with an iron block doesn't weigh that much more than the 215 (this swap has been done a lot). The Buick V6 was a factory option in the Skylark and in turbo or supercharged form could be fun. And it really pains me to say this, but an aluminum LS makes more sense than an iron 455.
Old Mar 9, 2023 | 05:17 AM
Rallye469's Avatar
Some interesting options for sure.
How similar was the '63 Chevy II's drivetrain layout to the F85's?
(really just interested in the rear interchangeability as it has much more AM support)
Old Mar 9, 2023 | 06:21 AM
Zero interchange. The Chevy II used a full unibody with a completely different front suspension, different floorpan, and leaf springs in the rear. The Y-body cars are based on the Corvair platform, but even then there are significant differences among the divisions. Besides the Corvair-derived transaxle, the Tempest used different front suspension, steering, and brakes from the F85 and Skylark. The Y-body Tempest was the only GM car to use the normally Ford/Chrysler 5 x 4.5" wheel bolt pattern (that's a trivia question for you).
Old Mar 9, 2023 | 04:30 PM
Rallye469's Avatar
Wow. I had NO idea how unique they were.
maybe it’s just better to toss in the LR rebuild and cruise it.
Definitely beautiful lines though. I’m really digging the 63’s in bothe the B-body and A-body platforms.
there a few of each down here for sale rather cheap for their condition.
Old Mar 9, 2023 | 07:03 PM
65B01Delta's Avatar
Get it running and drive, no need to dump a lot of $$ in it and a 3 on the tree awesome...
Old Mar 11, 2023 | 06:30 PM
307-5a's Avatar
Roy Ale
3 on the tree , my first car was 3 on tree , but now would think that would just about make the car theft proof !
Joe , good saying tire break out is a mechanical fuse
Old Mar 11, 2023 | 06:46 PM
Fact 😄
590moss
Non-Olds Engines
Dec 22, 2013 06:08 AM
Hammer7
Nov 17, 2013 11:27 AM
rjsam
May 18, 2013 06:08 AM
terryp
Jan 8, 2012 01:22 PM
radman58
Aug 22, 2011 09:35 PM
