Intro/ Engine
Engine Block
Did not seize the block. pouring oil out left head, right at gasket. no water in oil. But water is pouring out the tailpipe. Radiator is shot. big rip right on the weld. It is a 350 1972 #7 heads
You are going to have to remove that head. It sounds like the engine over heated and besides the damage to the radiator the head has cracked as well. You are probably in for a top rebuild at the least. Welcome to CO and keep us posted on what you find out.
Originally Posted by electraman87
........ pouring oil out left head, right at gasket ......... water is pouring out the tailpipe ........
While the head is off, have the combustion chambers magnafluxed. It's the area where Olds heads are prone to crack. If good, check the surface with a straight edge and a .001" feeler gauge. If good, put it back together with a new gasket.
Norm
wilfredacree
February 18th, 2009 06:30 PM
