Hi from Colorado
Old Sep 18, 2010 | 06:59 AM
68442CONVERTCO's Avatar
Aloha, Tony
Hi from Colorado
Hello everyone,
Here's a few shots of my 1968 442 convertible. It's numbers matching with a 4 speed. I will be building a 1965 400 B block with C heads to replace the original motor this winter. The build thread will be posetd in the Big Block section. I look forward to everyones advice and comments during the bulid.
[IMG] https://classicoldsmobile.com/forums...7/ppuser/29141 [IMG]
[IMG] https://classicoldsmobile.com/forums...8/ppuser/29141 [IMG]
[IMG] https://classicoldsmobile.com/forums...9/ppuser/29141 [IMG]
P.S. Does anyone have a link to make the actual photos appear in your posts?
Old Sep 18, 2010 | 07:03 AM
2blu442's Avatar
Signup at Photobucket or Flickr which are both free. You can upload your photos to there, then once they're there use the copy and paste options to put them in your thread. That's how I get photos to show up in the threads. John
Old Sep 18, 2010 | 07:04 AM
citcapp's Avatar
Nice drop top, mild or wild build or somewhere in between?
Old Sep 18, 2010 | 07:13 AM
Aloha, Tony
Thanks 2Blu I'll do that.
citcapp.. I'm thinking in between. Home porting of the C heads, W31 forged pistons, performer intake, Qjet, and a cam. I would like headers, but haven't found ones that will fit the 4speed ragtop.
Old Sep 18, 2010 | 07:55 AM
Oldsguy's Avatar
Past Administrator
Welcome to CO.
Old Sep 18, 2010 | 08:30 AM
geowindow6768's Avatar
I see you also borrowed the dash switches from a full sized 68 Olds. They definitely brighten up the dash.
Old Sep 18, 2010 | 09:18 AM
Welcome
Welcome aboard
Nice ride
Old Sep 18, 2010 | 09:26 AM
rcorrigan5's Avatar
Randy C.
To coin a phrase from Cousin Eddie, "....nothin' but the best.....!"
Randy C.
Old Sep 18, 2010 | 09:56 AM
Aloha, Tony
geo: Previous owner did that, and also used various non matching paints to redo the plastic trim and metal dash. Or the bonehead mechanic he was using did, actually I should thank him because tha'ts how i ended up with it... The owner had the trans rebuilt, and shortly after it broke again. The owner he had enough, and put it up for sale. When I called about it the car was already sold. I politely asked the owner to write down my number and call me if the deal fell through. Two days later he called me!
I had to overhaul the tranny, replace the clutch and flywheel, and overhaul the entire brake system. I'm still running the original four drum maniual brakes, but I did add power steering.
Old Sep 19, 2010 | 07:29 AM
Aron Nance's Avatar
Hello, Colorado, and welcome to CO! Not only do we like '68 wagons, we also like '68 convertibles, for some reason! Keep the pictures coming!!!
TECH9TWISTA
Mar 11, 2008 02:10 PM
bfreehill
Feb 18, 2008 09:38 AM
TECH9TWISTA
Apr 26, 2007 09:33 PM
