HELP OLDS EXPERTS! '62 vs. '63 CUTLASS TRANNIES
Old Aug 20, 2009 | 08:57 AM
62CUTLASSINKEYWEST's Avatar
help! i'm trying to locate a '62 olds cutlass f-85 convertible auto (hydramatic) transmission for a friend in florida. i spoke to a parts locator, who found only 2 in the country available (thru salvage yards). one for a '62, the other for a '63. he read in some parts book that the two years are interchangeable, which i find hard to believe, given the different body styles. could someone on here pls. let me know if this is the case. he did say that if i were to put a '63 transmission into a '62 that it would need different rear brg's and retainers. i'm by no means a mechanic. would that be difficult (particularly for a non-transmission expert located in key west, fl!)
thanks SO much!
best,
jimmy
Old Aug 20, 2009 | 09:58 AM
thanks SO much!
best,
jimmy
Don't let the different styling fool you. The 61-63 cars are basically the same. All are 112" wheel base and (believe it or not) are based on the Corvair platform. The Tempest actually used the Covair transaxle with a front mounted engine. The Olds and Buick versions were conventional front engine and trans. The 63 transmission will work fine.
Old Aug 20, 2009 | 11:48 AM
thanks, joe...i've been told that the '62 (and '63) olds' auto (hydramatic) transmissions were 3 spd. i hope that's right, as well...thanks again! best, jimmy
Octania
Mar 28, 2013 09:19 AM
OldsManNJ
Dec 8, 2011 12:16 PM
47 Convertible
Aug 20, 2009 05:59 PM
dmontanagrizzlies
Jun 19, 2009 09:27 AM
daverbmxer
May 26, 2006 06:04 PM
