Hello from Mi
Hello from Mi
new here have had a 72 cutlass s for quite a few years and just starting to get around to finish the resto I started back then found this forum and thought I could use some info from others on here maybe I can help some others as well
Near Grand Rapids thanks for the compliments in the process of installing a front disc brake Conversion at the moment and stuck at the point of hooking lines up thinking of replacing all lines with new
unless you have $$ to burn
leave those perfectly fine lines
save a buck
if the are faulty???
spend some
