Headers for 65 442
Old Aug 4, 2014 | 04:32 PM
65442ragtop's Avatar
Headers for 65 442
Just bought a 425 D block motor with G heads (instead of the B heads) which headers would fit in 65 442 with the least amount of modification, also motor has 4 speed crank did Oldsmobile make a 425 with crank bored for pilot bushing or did that happen after the fact ?
Old Aug 4, 2014 | 05:57 PM
oldstata's Avatar
Justin
If you look on 442bro.com
He lists a few headers that 65 owners have used also ton of info on his sight.
A few members have installed some maybe they will chime in as well
Old Aug 4, 2014 | 06:12 PM
Oldsmaniac's Avatar
The 425 crank was not drilled for stick unless it came in a standard trans designated engine.
Old Aug 4, 2014 | 06:56 PM
I know cranks were not either or, was there a factory 4 speed 425 engine
Old Aug 4, 2014 | 07:27 PM
Oldsmaniac's Avatar
Yes there were in 65 and 66 but thru all years 65-66-67 there was also 3 spd manual on the column as standard on some models with 425.
Old Aug 4, 2014 | 11:16 PM
64Rocket's Avatar
The early 400 (65/67) and 425 crank are the same. So a drilled crank is very possible
Gene.
soundhd
Aug 8, 2012 04:24 AM
onofre442
May 14, 2012 12:44 PM
Wyze
Mar 18, 2012 01:59 PM
62radarlove
Mar 7, 2012 04:16 AM
dean adkins
Sep 13, 2011 10:58 AM
