head code
I assume this is from a 1967 motor? If so, that's the engine unit number. R = 425 cu in 4bbl motor. 121209 = sequential unit number (should match the Protect-O-Plate). Not sure about the "T" suffix, however. I've seen that on Toronado motors.
It did not come from the factory like that. All 400 motors got engine unit numbers that started with the letter "V" that year. Of course, the same head castings were used on both motors, just the engine unit number was different.
