First Restoration
Old Mar 27, 2013 | 05:44 AM
dallas.fulton's Avatar
First Restoration
Hey all,
I'm restoring a '74 Omega. Not sure what engine was in it from the factory, but it finally ended up my garage it had a 454 in it. Ran a bit rough, so I bored it 60, put in an Eagle Competition Rotating Assembly, Edelbrock power package top end kit, MSD ignition, and topped it off with a demon 870 Carb. I also rebuilt the transmission, replaced the wiring and even replaced the driveshaft. That was before I had kids, now that I'm a father, I can't really afford to dump all my money into my car, so I've been looking for ways to keep restoring and not break the bank. So I heard a rumor that an early '80s SS Camaro rear end will pretty much bolt right in to replace the original. I still have the one wheel peel, and want the Positraction and disc brakes that would come with it. Any input is greatly appreciated!
Old Mar 27, 2013 | 06:41 AM
droptopron's Avatar
delete
There were no early '80's SS Camaro but IIRC any rear from a '70-'81 Camaro or Firebird will bolt in. A lot of the later Z28's had 3.42 or 3.73 ltd slip. Look for a four speed car w/out AC and it should have better gears.
Old Mar 27, 2013 | 08:10 AM
Welcome, post some pictures when you get a chance.
Old Mar 27, 2013 | 08:54 AM
Thanks for the info Droptopron! I'm already seeing what I can find in my area!
I didn't notice until now but I don't have many pictures of my Omega. But here you go, these are kinda old. I'll take some new ones when I get a chance.
Old Mar 27, 2013 | 09:10 AM
Black Sheep's Avatar
Nope. 70-81 rearends are wider and won't fit. 67-69 camaro/firebird rears will work. If your current 74 Omega rear is a 8.5 10 bolt, then you can use the guts out of a later rear. Check the rear you have now, it may be an 8.2
Edit with pic, 74 Omega rear on top, 81 Camaro rear under.
Old Mar 29, 2013 | 08:43 AM
Thanks for the info Black Sheep! It really helped! I actually already have an 8.5! So I'm just going replace the internals. I've been looking at limited slip diff's, I used summit for the initial search and it came up with an Auburn Gear Inc diff. I've never heard of them, so I thought I'd ask and see what's good brand that will give me the best bang for my buck. Also how can I tell what gear ratio I have? I haven't taken out my rear end yet, I just want to get a strong understanding of what I'm going to do before I actually start doing anything. Thanks for all the help!
Del70
Jul 21, 2020 11:42 AM
rsandhoff
Apr 10, 2012 07:12 PM
FIRST 442
Apr 5, 2011 04:33 PM
Boldsmobile
Oct 30, 2010 08:19 AM
Ravensmile
Jun 24, 2009 05:46 PM
