Exhaust Manifold Heat Shroud - 1970 Cutlass
Hello. I'm having a hell of a time locating (buying) an exhaust manifold heat shroud for my 70 Cutlass Supreme. Any suggestions? Thanks.
What size engine? Driver or passenger side? Are you looking for the exact 1970 one or would a different year that may have a different appearance work for you? I've got several in a box from 1968-72 vintage but will need to check and see the difference between the years if that's important to you. John
Hi John. It's a 350 v8 Rocket - 310 hp and the shroud would fit on the passenger's side. I'd like to maintain the correctness of the car so a 1970 would be preferable. Thanks for any information you can share.
Mike
Mike
Unfortunately, the only ones I've seen repro'd are for the big block cars. I'm afraid your only option will be to find a used one. Set up a search on ebay and it's pretty painless.
Mike
I believe this is the correct one, fits over a #4 manifold. If it looks good enough for you $10 plus shipping from Oregon. John
matchek
March 16th, 2015 04:23 AM
