1968 exhaust manifold heat shroud
I need the two piece exhaust manifold heat shroud for '68 only that goes on the passenger side.
I have the black vacuum-shaped piece and heat riser tube, I just need the 2 sheet metal pieces and hardware to wrap around the manifold.
It's reproduced, but only available for purchase with the vacuum piece and tube, which makes it pricey (I asked Fusick and they confirmed they can't split it up).
This is what it looks like for reference.,,
http://www.fusickautomotiveproducts....p?number=EMS68
Let me know what you have... thanks!
Unless you've replaced the crossover type manifolds with dual manifolds I think you're talking about two difference heat shields.
Luke,
As you probably know theses are hard as hell to find. I know someone that restored a 68 442 convertible that spend four years looking before found all the pieces.
matchek
Mar 16, 2015 04:23 AM
