Engine swap
Old February 18th, 2017, 10:52 AM
slickdriver's Avatar
Smile Engine swap
I have a 1983 Custom Cruiser wagon. It currently has a 307 V8. with all the smog equipment on it, it is a real dog on the freeway. Would like to install a crate 350 V8. Given the weight of this vehicle, what would be a good HP rating to target going forward?
Also, would a mid '70's Oldsmobile 455 fit into this GM B body car?
Thanks for letting me bore you to death. lol.
Slickdriver
slickdriver is offline
Old February 18th, 2017, 11:17 AM
Olds Fever
CRUZN 66's Avatar
Welcome to the site... A 350 would be a good choice for the 307 replacement... The mechanics would almost be a direct bolt in... Electronics/Carburetion would be a personal choice depending on your states emissions requirements... As for the 455, it will bolt in with the same electronic/carburetion concerns, but now you would have to deal with exhaust issues as well...
CRUZN 66 is offline
Old February 18th, 2017, 04:38 PM
Slickdriver
The 455 is an easy swap and bolt in using the 307 mounts an trans. The 200-4R trans unfortunately is not strong enough to live very long behind the 455 in stock form.
A 350 Oldsmobile is a direct bolt-in for the 307 as it is externally identical. All accessories, brackets, and manifolds bolt up. The 455 has a taller deck height and requires minor mods.
A 350 "crate" motor is code for Chevy and requires more work. It is not a direct bolt in, but obviously the B-body chassis can accept a belly button motor.
joe_padavano is offline
805cut
May 3rd, 2012 08:11 PM
'69CutlassVert'
August 25th, 2011 07:19 AM
oldsmobum
January 14th, 2011 10:10 PM
<maxone>
November 28th, 2008 11:57 PM
ferg87
August 3rd, 2004 08:33 AM
Quick Reply: Engine swap
