Engine number
Old Mar 9, 2013 | 07:56 PM
kellsbells's Avatar
Engine number
Hi, i am from Australia and i have added a 71 Cutlass Supreme to the family. There are not to many Cutlass 's down under .
It was imported by the guy who moved here,I have started a frame off resto
and already found this site a great place to find information
and was wondering if anyone could ID my Engine Number it is 47X140098 .
Will post photo's as the rebuild progresses
Old Mar 9, 2013 | 09:18 PM
hurst68olds's Avatar
Welcome to CO!!
if the 47X140098 is a partial VIN# stamped on the block:
4 = Buick
7 = 1977
X = Fairfax, KS GM plant
140098 = VIN sequence
Is it a 403? What's the casting number between the water pump & intake?
Old Mar 9, 2013 | 09:26 PM
kellsbells's Avatar
Casting number is 557265 4B ,i believe this is a 403
Old Mar 10, 2013 | 09:40 AM
jaunty75's Avatar
According to this page:
http://tech.classicoldsmobile.com/39.shtml
that casting number indicates a '77 to '79 403.
Old Mar 10, 2013 | 09:50 AM
70W-32's Avatar
Hey guys, first post, nice site.
doesnt the 77 and up motors have the size cast into the side of the block?
To the original poster.
Is your car converted to right hand drive?
Old Mar 10, 2013 | 08:18 PM
OLD SKL 69's Avatar
GM Enthusiast
Welcome to CO! Look forward to seeing pictures of your new ride restoration.
Old Mar 10, 2013 | 09:07 PM
I have started a frame off resto and was wondering if anyone could ID my Engine Number it is 47X140098
So you know the original engine is missing. Is your car by any chance a Cutlass Supreme SX? If it is it would have had a 455 2bbl. If not the standard engine was a 350 4bbl. Are you planning to keep the 403 or search for an Olds engine?
Welcome to the site. No the engines don't have the displacement cast onto the engine block. They do have the engine casting number which identifies the block (and that is associated with CID and production years)
BTW, you should hop over to the newbies section and post a hello to introduce yourself to the larger CO audience than just the ones viewing this thread.
Old Mar 11, 2013 | 02:48 AM
kellsbells's Avatar
its still lefthand drive cars over 30 years old dont need to be converted in my state
Old Mar 11, 2013 | 02:54 AM
kellsbells's Avatar
Yeh the original motor was replaced and no SX,still deciding on keeping the 403 or sourcing a 350,there are a lot of different opinions on the 403
Old Mar 11, 2013 | 08:20 AM
For a street driven car, why would you want to give up the extra 53 cu in? The alleged shortcomings of the 403 are only an issue in extreme driving (i.e., making the car a dedicated drag racer).
Old Mar 11, 2013 | 06:02 PM
QMaster's Avatar
Welcome to the Forum! You will learn a lot and people are always willing to help.
Old Mar 13, 2013 | 10:52 PM
70W-32's Avatar
Old Mar 14, 2013 | 07:06 AM
jaunty75's Avatar
That can't be the displacement. It's upside down!
Old Mar 14, 2013 | 11:03 AM
First time I've seen that. I stand corrected. Prior to the 403 though I'd suggest you won't find that casting. They might as well have just cast "SBO" on the side instead of 403. That would have been less confusing to some folks who argue that the 403 is a BBO.
Shouldn't your 403 be blue instead of gold?
Old Mar 14, 2013 | 11:05 AM
citcapp's Avatar
Welcome to CO
Interesting having the cu stamped on the engine block.
Old Mar 14, 2013 | 11:29 AM
Decided to look for more web images of this casting. Well apparently it's on both sides of the block to avoid confusion.
Old Mar 14, 2013 | 12:19 PM
70W-32's Avatar
The casting of the motor size on the side was probably for quick reference at the machining and assembly plants. You wouldnt want someone to load a 350 gas block on to the machining line meant for the 403's, that'd be a quick way to ruin a block and the tooling. Diesel blocks have D or DX cast in the same area.
Alg
Jan 1, 2013 05:04 PM
marcello
Ninety-Eight
Sep 5, 2008 05:20 AM
roadster-rob
Mar 9, 2008 10:24 PM
perro
May 2, 2007 02:39 PM
1BAD68"S"
Sep 17, 2006 06:49 AM
