Engine ID help
Old October 8th, 2012 | 10:43 PM
1932j2's Avatar
Question Engine ID help
Hello all, I am not an oldsmoblie owner. I am a retired Los Angeles County Firefighter. I do have a question. I just bought an old 1932 ford roadster and I would like to confirm what engine is in it. First it is an Oldmobile. It has a Muncey M 20 4 speed trans. Near the number 7 cylinder it is stamped R239123. The heads are casting number 16. The manifold casting number is 571145. It appears to to me to be a 56 block with a J 2 top end. Is this possible? Will the J2 top end fit and work on this block. It definately appears to have been used quite a bit. Maybe I have everything wrong also. Any help is appreciated. Thanks, Jim
Old October 9th, 2012 | 02:36 AM
Ozzie's Avatar
Red face Check a bit more
#16 heads should be 1957. The 571145 intake manifold should be a J-2 from 1957 or 1958. From 1956 to 1957 the stroke and deck height changed so mixing these parts results in mismatched ports. You can look at the rear of the engine, passenger side, bellhousing area for a cast number. 568922 should be for 1954-1956.
Old October 9th, 2012 | 02:48 AM
Ozzie's Avatar
Question An unknown
I don't have aything on the R239123. Exactly where is it located?
Old October 9th, 2012 | 09:59 AM
1932j2's Avatar
Thanks for your response! The casting number on the bellhousing is 561747. R239123 is stamped on the block deck just below the head between number 5 & 7 cylinder. Hope this helps. Regards, Jim
Old October 10th, 2012 | 04:12 AM
Ozzie's Avatar
Post Block needs a bit more research
I'm still drawing a blank on the block. While not guaranteed for an exact year, bore & stroke might narrow the search if they haven't been altered. Here's another site which often has some information on the stage 1 Olds engines: http://www.jalopyjournal.com/
nolabigdawg
November 16th, 2014 06:45 PM
805cut
May 3rd, 2012 08:11 PM
MJAKS462
April 15th, 2010 02:34 PM
Olds luvr
March 17th, 2010 06:57 PM
pinky
October 1st, 2007 11:24 AM
Quick Reply: Engine ID help
