Coolant temp sensor removal
Old Sep 15, 2016 | 08:31 AM
67oldsdelta88's Avatar
Hello all, new "again" to the forum here. I have a 1967 Delta 88 425 cui that has sat in my garage for 6 or so years. I have recently got it running again and I am doing some work to get it road worthy again. I have a cooling system related questions. I would like to install a mechanical water temp gauge into the intake. Could I just remove the coolant temp sensor (located at front left of intake manifold) and install the gauge in there? I guess what i am asking is does this sensor just control the dash "hot" indicator light? Or is there another function of it and removing it would cause problems with the cooling system? Thank You
Old Sep 15, 2016 | 09:30 AM
rjohnson442's Avatar
Mr. Johnson
You sure can.
Just a dummy light won't conflict with anything else.
Old Sep 15, 2016 | 10:35 AM
Thanks for the reply, that was the answer I was looking for! I have another cooling system question. A few years back I removed the heater core. I blocked off the heater core valve at the back of the intake with a rubber cap and hose clamp and did the same at the port on the water pump. Is this bad to do, will it effect coolant flow? If so, could I run a hose between the two ports?
Old Sep 15, 2016 | 10:57 AM
The factory simply capped those ports on cars that had heater delete. There is no problem doing that.
Old Sep 15, 2016 | 11:42 AM
jaunty75's Avatar
I don't know about other cooling system problems, but when I removed the temp sensor on my '67 Delta 425 to hook up a gauge, it caused a leak in the divariable veeblevurtzer. Fortunately, I had a spare!
Old Sep 15, 2016 | 11:47 AM
lol, I feel I've heard that term on star trek before...
tdhill01
Sep 15, 2016 04:01 PM
leit
Jul 14, 2014 07:35 AM
54oldz
Jun 20, 2012 07:13 PM
Aceshigh
Oct 1, 2010 10:35 AM
cormike
Aurora
Jan 4, 2009 07:30 AM
