Bought a 455 builder and here for advice
Old May 23, 2017 | 05:08 PM
jpayne_80@hotmail.com's Avatar
Hi, All. I bought a 455 (J heads) w/th400 for next to nothing. The block is in real good condition but I need to replace some things. After reading this site for a week I've learned a lot! I plan to put it into my '64 C10 (I know...boo...hiss) but it's going to take time and money.
I know I need the passenger side head, intake manifold, and carb...all cheap parts! I'm not looking to build for performance just stock. Is the Classified Parts Wanted portion of the site a good place to start?
Thanks!
Jeff in SW MO
Old May 23, 2017 | 05:19 PM
CRUZN 66's Avatar
Olds Fever
Welcome to the site... Yes, it may be beneficial to place an ad in the Classified Parts Wanted Section... As for the 64 C10, nothing wrong with an Olds Powered Chevy truck...
Old May 23, 2017 | 05:23 PM
don71's Avatar
same but different
Welcome Jeff. I like your plan and hope you find what you're looking for.
Old May 23, 2017 | 06:28 PM
Gary M's Avatar
Welcome to CO
If I read correctly your in SW Missouri. Good luck with the build. That C10 will have some good torque.
Old May 23, 2017 | 06:40 PM
classicmuscle442's Avatar
Olds torque monster in chev all good.
Old May 23, 2017 | 06:43 PM
Welcome to the site. There are a few members with Olds powered trucks. The parts wanted section is a great place to start.
Old May 23, 2017 | 07:00 PM
Yep. I'm about 6 miles from Arkansas.
I currently have a nice running 250 Inline 6 but when I buy a pontoon boat I don't want to worry about going up all of the hills around here.
Thanks, Guys. I will post in the wanted section. Maybe I can find some relatively inexpensive stock parts that others have sotting around from upgrading. A stock 455 is much more powerful than my 250!
Old May 27, 2017 | 11:56 AM
64Rocket's Avatar
In my opinion I would op for any other Olds head to replace the "J" heads.
A stock pair of "G" or "Ga" heads would be my go to head. They have factory harden valve seats and will flow way better than the "J" heads. Also and aftermarket aluminum intake will be a better choice than the cast iron one, and perform much better. IMO
Also I love Olds powered chebby's
Gene
Old May 29, 2017 | 08:20 PM
Thought I'd update my progress:
Purchased rebuilt G heads for $300.
The push rods and lifters look to be good AND the cam shaft is actually a Comp Cam Dual Energy cam. It is number 42-208-4. Here is it's details http://www.compcams.com/Company/CC/c...csid=1179&sb=2
The pistons are stamped with 30 on them so I assume the engine has already been bored over. There is some rust on a couple of cylinder walls so I figure it will have to be bored over again. I'll be taking the block in to a local machine shop (builds race engines with high recommendations) to see what needs to be done.
I have yet to remove the oil pan (no engine stand yet) to take a look at the crank and bearings. Praying there isn't a spun bearing.
This is my first tear down and "rebuild". It will take time and money, of course, but I cannot wait to get this on my c10!
Old May 29, 2017 | 09:16 PM
That is a mild cam for a 455, but it'll probably have a buncha low end torque, but not rev very high.
Old May 29, 2017 | 09:27 PM
I think I may have to get a new cam anyway. I mixed the lifters up, dagnabbit!
I see the Engle 18-20 and 20-22 mentioned a lot.
Old May 30, 2017 | 06:09 PM
You could just get a new set of lifters.
Before buying a new cam, you should figure out what pistons you have / what the compression ratio is so you get a suitable cam.
Old May 31, 2017 | 05:28 PM
I will wait on the cam to see what comp ratio like you advise.
Here are a couple of pictures of the bottom end of the engine. No spun bearings, yay. See anything of great concern?
Old May 31, 2017 | 09:09 PM
64Rocket's Avatar
Have any pic's of the pistons?
Can you tell what brand they are?
flat tops or dish ?
Gene
Old Jun 1, 2017 | 07:44 AM
Here is a picture of one:
Old Jun 19, 2019 | 02:41 PM
Well, here we are 2 years later and I'm finally ready to install the 455. Bored it 60 over and installed a Erson TQ 50 cam thanks to Mike. It has been broken in, and I'm currently cleaning up years of dirt from the crossmember and frame in the C10's engine bay.
Here is a video of it running after break-in:
Old Aug 5, 2021 | 08:16 PM
Wow! I completely forgot to update this thread! Everything is running great other than a small trans pan oil leak! Hear is a short clip of it idling. Exhaust is true dual 3" with Hooker Aerochamber mufflers exiting after the rear axle. Sounds great and will roast the tires!
May 24, 2017 09:35 PM
yearby73
Oct 4, 2016 02:57 PM
TimKillinger
Jun 5, 2012 10:49 AM
blueohbaby
May 20, 2012 11:14 AM
projectheaven
Nov 28, 2008 07:16 AM
