Battery drain
Old December 23rd, 2021 | 06:14 AM
J1978's Avatar
Battery drain
I have a 78 delta 88. Trying to find out why my battery is draining. I have the right specs on the battery. My clock doesn’t work. I make sure everything is off after driving any information is appreciated thanks
Old December 23rd, 2021 | 07:28 AM
Hammerdrop's Avatar
Think I would try disconnecting the alternator. An Amp Clamp or amp meter would help.
Old December 23rd, 2021 | 10:11 AM
EdwardB's Avatar
Try taking your battery and alternator out and have them both checked at an automotive parts store. If they both check out fine use a multimeter on the battery to find what system is drawing. Use u-tube to watch videos on how to do that, there are several. Usually you'll find that the alternator just isn't putting out enough voltage to charge the battery. It's a slow death for the battery. If you have a voltage meter on the vehicle look to see if you have 14.2 volts at Idle.
Old December 23rd, 2021 | 10:18 AM
rocketraider's Avatar
Oldsdruid
How often is this happening? Overnight, weekly, monthly?
First, check alternator output. If you don't have a multimeter, you can get one at a chain parts store or Harbor Freight for less than 20 bucks.
With engine running, check alternator output voltage at the output post. It will have a heavy gage red wire on it. Should be 14 volts. If not, bad alternator.
Then check voltage at the battery (+) terminal. Should be same as alternator output voltage. If not, there's a wiring problem.
If these check good, time to start searching for a current draw.
Let us know what you find on alternator and battery. We'll go from there.
Old December 23rd, 2021 | 10:20 AM
You should have 14.2v @idle and a fully charged battery should be 12.6v with the engine off.
Old December 23rd, 2021 | 08:47 PM
edzolz's Avatar
Check to find the drain like this. Dissconnect your ground from the battery. Connect a test light to the ground terminal and ground the test light. If you have a drain the test light will be on. If you have a drain, pull fuses one at a time until the light goes out. When the light goes out that is the circuit that is causing the drain. This does not work if your alternator is causing the drain.
Old December 24th, 2021 | 12:13 PM
tnswt's Avatar
'70 4-Speed W Machine
edzolz great feedback. So one could disconnect the alt and proceed as you describe?
Old December 24th, 2021 | 09:13 PM
edzolz's Avatar
No, if it is the alternator and it is bad, it will show a drain (the test light will be on) until you disconnect the power to the alternator.
Jon442
May 10th, 2021 07:31 AM
4speed455
March 12th, 2021 10:31 AM
Sugar Bear
September 18th, 2020 12:41 PM
Neil Morrison
February 28th, 2020 06:35 PM
VikingBlue
February 11th, 2012 10:24 AM
Quick Reply: Battery drain
