adding 455 big block to my '72 cutlass "S"
Old August 22nd, 2013, 10:57 AM
moeviking's Avatar
72 was factory with Olds 350. I purchased with sm. blk chevy. i would like to put 455 Olds in place of sm. blk chevy. any thoughts as to the difficulty,parts needed, etc. I am new at this, thusly my questions.
moeviking is offline
Old August 22nd, 2013, 11:41 AM
Which trans is in the car, you are going to need a Buick, Olds, or Pontiac trans to make it work.
You are also going to need frame brackets and motor mounts for an Olds.
Some minor wiring changes will be required also.
You will also need all the accessory brackets for the 455.
Other than that, pretty simple.
oldcutlass is offline
Old August 22nd, 2013, 06:00 PM
68conv455's Avatar
Depending on the radiator you may need a bigger one. Don't worry about it until you have the new motor running and determine how well it cools.
you may also want to install a posi rear and increase your tire budget.
68conv455 is offline
Old August 22nd, 2013, 09:26 PM
svnt442's Avatar
My guess would be that the original wiring is all hacked up anyway so it may be a good time to just replace the harness with a new one. They really aren't all that expensive and in the grand scheme of things it makes that car all that much safer.
svnt442 is offline
terrapin
August 7th, 2012 06:25 PM
yeahbuddy
April 5th, 2012 01:24 PM
joepenoso
November 7th, 2011 07:18 AM
81 regency
April 21st, 2011 06:18 PM
Quick Reply: adding 455 big block to my '72 cutlass "S"
