77 Cutlass Ignition Switch
Old Mar 19, 2012 | 10:57 AM
DZLFRK's Avatar
Cool 77 Cutlass Ignition Switch
Anybody have a diagram or installtion instructions to replace the ignition switch on 1977 Cutlass? I haven't looked at it yet, is it on the column under dash, or do I need to pull the steering wheel? Thanks guys!
Old Mar 19, 2012 | 11:08 AM
I believe that the '77s are still the same as the '69-and-up years.
You have to drop the column (remove under dash trim piece, remove nuts holding column to dash support), then get up above it, just behind the pedal hanger, and you will find the ignition switch screwed to the top of the column.
Remove plugs, unscrew, replace (make sure actuating rod is in the right place), plug in plugs, reattach column.
Old Mar 19, 2012 | 11:41 AM
DZLFRK's Avatar
Thanks for the quick reply! That did it! Thanks for the help, Eric!
Old Mar 20, 2012 | 01:30 PM
mpolds's Avatar
1977 Olds Cutlass Turn Signal Switch
The 1977 Olds Cutlass Turn Signal Switch is one that goes all the way through the steering column -- to connect to the main dash harness...
I have exactly one (1) !!!!!! N.O.S. ++ DELCO ++ MADE IN U.S.A. ++ with all the ogiginal color wires etc. --- to make for the easiest hook up of your lifetime !!!!!!!!!!!!!!
Some Turn Signal Switches go for $ 100 - 150 & up......
For this 1 last 1 I have -- it is yours for $ 45 + actual UPS to wherever
you are in the world!!
Best to call me -- Craig -- 516- 485 - 1935....New York... Thanks.
Old Mar 22, 2012 | 12:03 PM
DZLFRK's Avatar
Hey Craiger, what part of "ignition switch" did you miss? LOL If I ever need a turn signal, I'll let you know, thanks!
Dpc2
Oct 6, 2012 03:44 PM
Joffroi
Oct 2, 2011 03:33 PM
LIOlds
Jun 21, 2011 06:30 PM
yeahbuddy
Feb 3, 2010 04:39 PM
toms1966rgtop
May 17, 2009 07:19 PM
