72 Olds Cutlass emergency brake doesn't work
Old April 27th, 2017 | 06:25 AM
LJ72Cut's Avatar
My emergency brake doesn't work and I don't know where to start with this. When I press the break I don't feel any tension and the pedal just goes down. Any advice will help. Thank you.
Old April 27th, 2017 | 06:52 AM
mrolds69's Avatar
The e brake uses the rear brakes. The rear brakes are connected to the parking brake pedal by a cable. The cable needs to be reasonably tight to work. there are 3 hooks that hold the cable. You need to crawl under the car and look at the cable. Either it's missing the hooks, the cable is missing, loose, wrong length...who knows? Crawl under and see if it's there and not flapping around.
Old April 27th, 2017 | 07:10 AM
First you need to remove the wheels, drums, and inspect the rear brakes. Make sure the cables are attached, the shoes are not worn out, and you have no leaks in the wheel cylinders. Replace worn parts and adjust as required.
Then follow the cables toward the front and make sure they are routed and interconnected properly. Look under the dash at the E-brake assy and make sure the cable is connected to the mechanism correctly. Go back to the adjuster under the car and adjust so the E-brake pedal engages the rear brakes at about 1/3 of the way down to the floor from its fully released position.
GOldman
January 9th, 2013 04:21 PM
sammicurr86
February 25th, 2012 01:20 PM
Olds64
December 12th, 2009 02:49 PM
seabeepirate
Drivetrain/Differentials
August 28th, 2009 08:19 PM
rcorrigan5
June 24th, 2009 03:15 AM
Quick Reply: 72 Olds Cutlass emergency brake doesn't work
