72 convertible top
72 convertible top
Hello, I have a 72 convertible, and the fuse seems to overheat, and then power top motor quits. Once it cools, it will run again for a few seconds.
Assuming it's the fuse, where can I get a new one. If not the fuse, then what?
I have a very similar condition with my '72 top motor. On the bench, the motor (seems to) spin fine, but when I install it, it dies once it is heavily loaded. Wait a minute or so - and it will run for a few seconds, then quit. I've been tryign to avoid paying $350 for a new one. I've torn that thing apart 10 times over as many years trying to fix it. Does anyone offer a rebuild kit (with instructions?) Can you rebuild that kind of motor or does it eventually just die? I've looked in the service manual and can't find a breakdown of the motor. With the motor apart, what are some things to look for (brushes, windings, etc.) Are there any places in the circuit upstream of the motor to look? Haven't tested the switch, but for some reason I don't think that's the problem.
Probably the circuit breaker. Not sure about the 72s but likely that same setup as my 69. There's a breaker mounted on the firewall near the brake cylinder booster. It will cut out when it overloads then reset when it cools. You can try replacing it but I would bet the top motor is just drawing more current due to old wiring or old motor or maybe something binding up on the top frame. Maybe some lube around top frame might help too.
Thanks guys. I'll lube the top frame joints, and check the breaker. Beob, any info on what this breaker looks like? don't know why I'm so adamant about not getting a new motor - I guess I just figured that it seemed like a rebuildable component; that and I'm used to opening my top by hand now anyway...
The circuit breaker is behind the brake booster towards the fender and it has a rubber boot over it with wires coming out on either end... when you carefully pry the boot to one side you WILL see two studs with nuts holding the wires to the breaker...
GoBigRed
Brakes/Hydraulic Systems
15
October 5th, 2015 01:00 PM
ros6872
October 31st, 2014 05:04 PM
Bobac455
August 27th, 2011 03:20 PM
Olds luvr
December 2nd, 2010 08:26 AM
