72 350 alternator power steering bracket pics
Old May 6, 2012 | 03:27 PM
Eldomiwok's Avatar
Putting my 350 back together need pics or diagram it had ac I took that out have top bracket. Power steering to alternator is a gap what go's n between. Thanks
Old May 6, 2012 | 03:37 PM
2blu442's Avatar
In 1972 there was a sleeve spacer that goes over the bolt. Here's a couple photos. The first shows the stud used the second is with the spacer over the stud. John
Old May 6, 2012 | 04:45 PM
Eldomiwok's Avatar
Thanks the bracket is lower alternator bracket bolts to power steering pump and block or xaust manifold still cAnt put pics on here
Old May 6, 2012 | 04:47 PM
Eldomiwok's Avatar
Thanks it's bracket between steering pump an alt bolts to alt block an power steering pump
Old May 6, 2012 | 05:00 PM
2blu442's Avatar
Sorry, I immediately thought of the spacer down low on the power steering pump. I didn't think the 1972 brackets shared any parts, but maybe I'm getting the years mixed up. Does your setup look like this? If so, do you have the stock intake? Do you have the spacer between the side of the block and the lower power steering bracket? Do you have the spacer I previously posted pictures of? If you have something like these photos there should be no space between the two brackets, so I'm thinking something else is throwing them out of alignment. John
442mark
Sep 30, 2017 01:06 PM
rvandeven
Aug 4, 2014 11:01 AM
nicks1966
Jan 12, 2014 01:46 PM
QS442
Nov 13, 2013 06:48 AM
xerxes600rr
Aug 30, 2011 06:43 AM
