71 Green Olds
Old May 14, 2012 | 03:15 PM
Zano67's Avatar
71 Green Olds
I have a 71 that blows hot air into the passenger compartment.
Does anyone have an idea what it could be??
Heater control valve??
thanks
rick
Old May 14, 2012 | 03:46 PM
Olds_71_442's Avatar
Hot air from the heater fan or do you have a hole in the firewall with the hot air from the engine blowing into the cab of the car?
Old May 14, 2012 | 03:58 PM
*ssholesGarage's Avatar
could be what 442 says and another thing is the controls from the dash being broken or stuck on or open
Old May 14, 2012 | 07:24 PM
Unfortunately, the mind reading thing STILL isn't working, so perhaps you could share what model, does it have A/C or not, Comfortron or not, etc. Diagnosis will depend on what you have.
Old May 15, 2012 | 07:36 PM
Zano67's Avatar
It seems to be coming in from floor heater vent
Old May 15, 2012 | 07:38 PM
Zano67's Avatar
1971 cutlass supreme 350 automatic with a/c but not sure what type
Old May 16, 2012 | 05:28 AM
jaunty75's Avatar
C'mon man!
He TOLD you right there in the title of the thread that it was a '71 and that it was green. What more do you need?
Man, you're picky!
Old May 16, 2012 | 06:11 AM
Originally Posted by jaunty75
C'mon man!
Man, you're picky!
DOH! Of COURSE! How could I have missed that...
Old May 16, 2012 | 06:19 AM
droptopron's Avatar
delete
Check the heater control valve. Loop the hose around TEMPORARILY so the heating system is disconnected and see if that corrects it. If it does that rules out it being engine heat that is entering the cabin.
Old May 16, 2012 | 06:21 AM
The flapper doors in the HVAC distribution box under the dash are vacuum operated. If the vacuum source hose is not connected properly to the engine, or if the hoses under the dash are disconnected, or if one of the vacuum diaphragm acutators has failed, the system will not work properly.
Old May 17, 2012 | 06:29 PM
Zano67's Avatar
I really appreciate the responses and I have some work to do.
thanks talk to you guys soon!!!
rick
Moto
Mar 1, 2015 03:48 PM
vistacruiser67
Cars Wanted
Nov 22, 2012 06:01 PM
360scamp
Sep 22, 2010 03:46 AM
bigblockolds
Sep 11, 2010 10:10 AM
ent72olds
Paint
Jun 30, 2009 01:42 PM
