'70 olds cutlass, widest tire up front 15" rim ?
newbie here, just picked this up, hoping someone can help I want to go wide as possible up front, looking for a low level stance stock car oval track look,with wheels tucked nicely inside wheel well. The rear is tubbed and currently has a 31x16.5 tire on a 15x12"rim with a 5.5 backspace. I'd like the rear tires to fill the wheel well even more, I have at least 2"inside and outside to work with. I'm thinking 15x14 rim with diameter around 28". Hope the pic attaches
I wasn't sure exactly what you were asking before.
I also have 245-60-15s on factory SSIII wheels, and have not had issues with rubbing. There seems to be plenty of clearance all around. Back in the 80s a tire shop inadvertently put one 255-60-15 on the left font and it rubbed slightly during turns. You may be able to get away with 255s depending upon your suspension setup - mine was factory original back then, so maybe sagging a bit.
rocketbob54
July 31st, 2016 07:09 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
