'70 olds cutlass, widest tire up front 15" rim ?
Old Jan 26, 2018 | 08:49 AM
Johnnylindo's Avatar
newbie here, just picked this up, hoping someone can help I want to go wide as possible up front, looking for a low level stance stock car oval track look,with wheels tucked nicely inside wheel well. The rear is tubbed and currently has a 31x16.5 tire on a 15x12"rim with a 5.5 backspace. I'd like the rear tires to fill the wheel well even more, I have at least 2"inside and outside to work with. I'm thinking 15x14 rim with diameter around 28". Hope the pic attaches
Old Jan 26, 2018 | 09:08 AM
Why all the info on the rear tires when the thread title is asking about the front tires?
Old Jan 26, 2018 | 09:14 AM
Welcome to the site, I fixed your picture. Nice ride. What size wheel are you running up front?
Old Jan 26, 2018 | 09:40 AM
Wheels
Sorry not so fun71, I left out back wheels, it's been frustrating trying to figure this all out, I'm not very savvy with computers , thanks for the welcome oldcutlass, up front are 165-80-15
Old Jan 26, 2018 | 09:43 AM
stevengerard's Avatar
I believe I have 245 60 15 on the front and they rub occasionaly when turned to lock and going up an apron or other steep incline.
Old Jan 26, 2018 | 09:44 AM
S
Sorry Weld wheels
Old Jan 26, 2018 | 10:17 AM
I've run 255/60-15s in the front on stock rims with zero offset.
Old Jan 26, 2018 | 10:19 AM
Steve and joe, what is your rim size? Width?
Old Jan 26, 2018 | 10:22 AM
Sorry, I should have added that. 15x7, zero offset.
Old Jan 26, 2018 | 11:14 AM
So I got a 15x7 on a stock rim with zero offset and a 15x8 with a 5" back space that may work hmmmm
Old Jan 26, 2018 | 05:12 PM
I wasn't sure exactly what you were asking before.
I also have 245-60-15s on factory SSIII wheels, and have not had issues with rubbing. There seems to be plenty of clearance all around. Back in the 80s a tire shop inadvertently put one 255-60-15 on the left font and it rubbed slightly during turns. You may be able to get away with 255s depending upon your suspension setup - mine was factory original back then, so maybe sagging a bit.
Lsx442
Wheels and Tires
Feb 4, 2024 02:58 PM
rocketbob54
Jul 31, 2016 07:09 PM
MDchanic
Wheels and Tires
22
Aug 4, 2011 10:23 AM
jtriggy
Wheels and Tires
Feb 22, 2010 05:47 AM
