68 cutlas s manual overdrive
Old February 27th, 2014 | 05:26 PM
odey1979's Avatar
I have a 68 cutlas s with a 3 speed manual and I want to put a manual overdrive in it for highway use. Anyone done this and if so what will fit? Thanks in advance.
Old February 28th, 2014 | 07:57 AM
The easiest way to get a manual trans with O.D. that fits is to find one of the A833 four speeds with O.D. These were used in Chevy pickups in the 1980s and the Chevy version should bolt to your bellhousing (there are also Chrysler versions). I don't know about overall length or yoke spline count, however. Note that Ford had a similar Toploader four speed with O.D., and while the trans will bolt to your bellhousing, the Ford input shaft will be wrong.
Options beyond that are expensive and require more work. The T5 is commonly available but weak. Even the World-Class versions are limited to about 300 ft lbs. You would need a V8 version from an F-body, and these have the angled shifter so you'll need an aftermarket shifter to work in your application. Fabrication will be required to get the shift lever correct, especially if you have a console. Again, I don't know about crossmember location or driveshaft length. The good news is that the GM T5s use the same yoke as your trans.
Beyond that are the aftermarket five and six speed transmissions, such as Richmond, TKO, etc. Some of these bolt to your bellhousing, some do not. You can also get an aftermarket bellhousing that allows a T56 from a later F-body to bolt to a BOP block. All of these will require floorpan mods, crossmember mods, and driveshaft mods. All will run about $2500 installed, or more.
Old February 28th, 2014 | 08:20 AM
66400's Avatar
Chevrolet offered a Saginaw 3spd OD trans 65-69 in passenger cars and light trucks.
Also 55-64 Chevrolets had a muncie 3spd OD trans but it was a non syncromesh first gear.
Henry
Old February 28th, 2014 | 08:29 AM
odey1979's Avatar
Thanks guys. I'm just hoping to stop the engine from crying for mercy at highway speeds. I'll look into those options
Old February 28th, 2014 | 09:05 AM
What gear ratio are you running? You can also add a gear vendors overdrive if your just looking at dropping your rpms and not going to a 4 speed.
Old February 28th, 2014 | 09:42 AM
odey1979's Avatar
Not sure yet of the gear ratio. What is a gear vendors overdrive. I don't want to change the rear end ratio since first is already pretty high. A 4 speed and new gears. Ok. That could work but just tossing a 3 speed with over drive in would be ideal for me. And yes. Main concern is to lower rpms at higher speeds but not loose the low end I so have. Thanks again
Old February 28th, 2014 | 01:21 PM
The GearVendors O.D. is an external unit that mounts behind your current trans and has a set of overdrive gears in it. Expect to pay ~$2500 plus the cost of a new driveshaft.
A used A833 can be had for a fraction of that. I've seen them for $700 on CL.
The overdrive configuration with a 23-spline input appeared in these vehicles:
o 1975 to 1979 Valiant, Duster, Dart, Scamp, Swinger, Volare, Aspen (3.09:1 ratio first gear)
o 1975 to 1987 Dodge light-duty pickups and Dodge and Plymouth Vans (3.09:1 ratio first gear)
o 1977 to 1979 Diplomat and LeBaron (3.09:1 ratio first gear)
GM used this same transmission with GM's own 10-spline input shaft, input bearing and retainer:
o 1981 to 1986 Chevrolet 2- and 4- wheel drive pickups and Suburban (3.09:1 ratio first gear)
o General Motors designated this transmission code MY6.
Old February 28th, 2014 | 01:27 PM
OK, sorry for the mis information. The Chevy version A833 used a unique bellhousing. This trans does not bolt to a normal BOP bellhousing, though it does have the usual GM ten spline input shaft. It also uses the larger truck bearing retainer, not the smaller automotive one.
It is possible to machine an automotive bellhousing to fit the truck bearing retainer, and it's also possible to change the bearing retainer on the trans (Jeep guys do this for SM465 swaps), but you'd need to modify the BOP bellhousing for the correct bolt pattern. The good news is that the bearing retainer is what locates the trans, so the bolt locations need not be super precise.
Old February 28th, 2014 | 01:28 PM
Here's a little more info on this swap into a Chevy.
Old February 28th, 2014 | 01:51 PM
odey1979's Avatar
I actually have that A833 trans in my storage trailer but it's set up for 4 wheel drive. I'd have to change the tail shaft to use it. Im looking around and thinking maybe ill just go with a 4 speed Saginaw or Muncie and change the rear end to a different gear. Maybe do a 442 setup.
Old March 2nd, 2014 | 01:22 PM
Oldsguy's Avatar
Past Administrator
Welcome to CO, smooth sailing at lower RPMs soon eh?
Old March 2nd, 2014 | 01:40 PM
Octania's Avatar
I was told some time ago in looking into getting a Muncie redone that they can now make these overdrive 4-speeds. Basically, straight thru is 3rd gear and then alternate gears where 3rd used to be are now overdrive 4th. Flip the 3-4 actuating lever over and it's all set.
I have no experience with this voodoo so cannot say if it's feasible or a good idea.
Old March 2nd, 2014 | 04:13 PM
This is exactly how the factories made the OD versions of the A833 and Ford Toploader four speeds. These transmissions retain first, second, and fourth (which becomes third) gears and swap out the former third gears for an OD set that then becomes fourth when you flip the shift lever. Unfortunately, nothing for a Muncie is cheap anymore, and you end up with a wide ratio four speed.
The reality is that the ratios in the trans and the rear end by themselves don't matter. What matters is the effective final drive ratio. For example, 3.91 gears with an 0.78 OD are the same as 3.08 gears with a 1:1 fourth. Of course, the difference is the effective ratio in first, which depends on the trans. For example, if you did Chris' Muncie gear swap in a close ratio trans, the 2.2 first yields an effective 8.6:1 final drive ratio. If you started with a stock wide ratio Muncie, the 2.52 first and 3.08 gears gives you an effective 7.76 final drive ratio.
Old March 2nd, 2014 | 09:18 PM
OLD SKL 69's Avatar
GM Enthusiast
Welcome to CO! Hope you get your trans situation straightened out. I've installed aftermarket overdrives: Borg Warner, Tremec etc. with great results. Much better for cruising and their built to handle the power output.
KEVO35
Bravada
December 8th, 2012 09:44 AM
skryla
March 2nd, 2011 09:01 AM
projectheaven
26
August 10th, 2008 12:26 AM
72RocketPower
May 26th, 2007 08:23 PM
72RocketPower
Drivetrain/Differentials
June 29th, 2006 03:37 PM
