68 442 sway bar
Old August 21st, 2018, 09:07 AM
Billyaxe's Avatar
68 442 sway bar
Hey guys, I’m looking at a 68 442 and the sway bar is up against the differential. Is that okay? The seller says sometimes they are set that way. Thanks —Billy
Billyaxe is offline
Old August 21st, 2018, 09:23 AM
JohnnyBs68S's Avatar
When I added a rear sway from a '69 442 to my rear axle (stock LCAs w/ spacers for reinforcement), it made contact w/ the diff housing. Since then I've swapped to the SSM LCAs and the same sway bar is ~ 1/4" away from the housing. I don't think it does any harm for the sway bar to contact the housing.
JohnnyBs68S is online now
Old August 21st, 2018, 11:46 AM
Billyaxe's Avatar
Great info. Thanks. I love these message boards. —Billy
Billyaxe is offline
Old August 21st, 2018, 12:09 PM
Rocket Renegade!
Have a good look and make sure the control arms are the correct boxed type. I've seen unreinforced arms drilled for the swaybar resulting in a funky fit.
BangScreech4-4-2 is online now
Old August 21st, 2018, 01:10 PM
Production tolerances on these cars were not exactly "precision" in a lot of cases. You can sometimes simply loosen the four bolts holding the bar to the lower arms, reposition it, and tighten the bolts. It's also possible that the bushings in the lower control arms are worn, causing unwanted motion.
joe_padavano is offline
Old August 21st, 2018, 06:59 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Additionally, make sure the lower control arms are actually "boxed" and someone didnt try to add/cobb a sway bar to unboxed arms. Ive seen this pre-digital age and should have taken a pic for our junkyard dogs thread.
droldsmorland is offline
Old August 21st, 2018, 11:27 PM
Rocket Renegade!
Great minds ...
teamwieland
July 27th, 2019 07:35 PM
teamwieland
May 19th, 2019 07:06 PM
Charles Ludwick
December 30th, 2011 07:14 AM
Lady72nRob71
October 17th, 2009 10:48 AM
Topless72
January 6th, 2009 01:18 PM
Quick Reply: 68 442 sway bar
