67 Tornado steering wheel
Hello I am new to this forum . I am looking for a complete steering column for a 1967 olds Toranado tilt steering wheel or a 1965 olds dynamic. 88 tilt column. I have a 1965 olds dynamic 88 convertible that has a olds toranado steering column and needs replacement or anyone knows anyone that overhauls column. The cable turn system unit broke and the only way I can get the signals to work is manually ,also this car has the side marker lights . Any help would be appreciated. Thanks Herm.
I mean cornering lights,sorry about that mixup. Or the turn signal unit inside of the column is bad. Cannot find anyone here in Florida that repairs Oldsmobile steering columns of that vintage. Any replies would be helpful.
Is your problem the cable or the switch itself? Are you sure it's a Toro column or just the wheel? This thread provides some info on the 65-66 Tilt/Tele switches.
It’s the unit inside the column that attaches to the cable inside the column. The switch itself that is mounted on the outside of the column is good it’s nearly impossible to find a replacement unit that mounts inside the column. It’s plastic and just wore away. It’s a toro column from a 67 toronado.clan replace it with a 65 olds tilt column, with cornering light unit.
GTMeach
August 25th, 2018 04:26 PM
