67 Tornado steering wheel
Old Jan 27, 2021 | 04:17 AM
allistar1's Avatar
Herm
Hello I am new to this forum . I am looking for a complete steering column for a 1967 olds Toranado tilt steering wheel or a 1965 olds dynamic. 88 tilt column. I have a 1965 olds dynamic 88 convertible that has a olds toranado steering column and needs replacement or anyone knows anyone that overhauls column. The cable turn system unit broke and the only way I can get the signals to work is manually ,also this car has the side marker lights . Any help would be appreciated. Thanks Herm.
Old Jan 27, 2021 | 05:27 AM
Do you mean "side marker lights" or "cornering lights"? Oldsmobile didn't install side marker lights (which are small yellow lights on the front fenders and small red lights on the rear fenders) until the 1968 model year, when they were required by federal law. Cornering lights, however, are white lights on the front fenders that light up on turns and those WERE an option in the 1965 model year. Cornering light and side marker lights are completely different and wiring and turn signal switch are different as a result. Which one do you have?
Old Jan 28, 2021 | 07:02 AM
allistar1's Avatar
Herm
I mean cornering lights,sorry about that mixup. Or the turn signal unit inside of the column is bad. Cannot find anyone here in Florida that repairs Oldsmobile steering columns of that vintage. Any replies would be helpful.
Old Jan 28, 2021 | 07:11 AM
allistar1's Avatar
Herm
1965 Oldsmobile dynamic 88 factory options + heavy duty upgraded brakes
Original calif car no rust!
Old Jan 28, 2021 | 08:14 AM
Is your problem the cable or the switch itself? Are you sure it's a Toro column or just the wheel? This thread provides some info on the 65-66 Tilt/Tele switches.
Old Jan 28, 2021 | 08:27 AM
allistar1's Avatar
Herm
It’s the unit inside the column that attaches to the cable inside the column. The switch itself that is mounted on the outside of the column is good it’s nearly impossible to find a replacement unit that mounts inside the column. It’s plastic and just wore away. It’s a toro column from a 67 toronado.clan replace it with a 65 olds tilt column, with cornering light unit.
jerbear2
Tech Editor's Desk
Jan 10, 2020 08:20 AM
kcrennie
Nov 14, 2019 12:24 PM
GTMeach
Aug 25, 2018 04:26 PM
LAYDBK98
Aug 4, 2015 11:17 PM
sgtoro
Apr 8, 2012 09:35 PM
