67 cutlas330
Old May 11, 2015 | 06:13 PM
rocket67's Avatar
67 cutlas330
Hello everyone, have been considering converting my two speed autp trans in my 67 F85 over to 4 speed manual. Any help with parts interchangeability between 330, 350, 400 engines, front and rear mounts, etc. would be greatly appreciated. Good day to everyone.
Old May 12, 2015 | 07:44 AM
Welcome. This question comes up a lot and the SEARCH function will yield many threads about it. There are a couple of things you need to be aware of:
1. Olds typically did not drill the crankshaft for a pilot bearing if the car originally came with an automatic. You will either need to pull your crank and have it machined or use one of the aftermarket conversion bearings. The latter requires you to trim about 3/4" from the tip of the transmission input shaft or to drill a non-critical clearance hole in the end of the crank. The latter can be done with the engine in the car but is not easy.
2. All 1964-1990 Olds motors use the same BOP bellhousing, however the 64-67 cranks use a different crank flange bolt pattern than the 68-up motors. You must use a 64-67 flywheel.
3. The frame-side bracket for the clutch equalizer shaft is welded to the frame on the 64-67 cars. You can get the bracket as a repro, but you'll need to locate it properly and weld it, or use a hydraulic clutch. The latter will require fabrication.
4. The Muncie and T10 transmissions are the same length as your Jetaway automatic. The trans crossmember stays in the same place. You can also use your current driveshaft, however the AT 'shaft is a two-piece concentric assembly with rubber isolators between the tubes. The four speed 'shaft was a one-piece design. The AT shaft will work, but it won't be correct. That's an expense you can put off to a later date.
Old May 13, 2015 | 06:27 AM
rocket67's Avatar
67 cutlas330
Thanks for the info. Now to find a crankshaft.
Old May 13, 2015 | 07:05 AM
Oldsmaniac's Avatar
I believe all small block cranks have the same specs. Yours is the stronger forged crank however. It has been said that all 403 sb cranks are drilled for the pilot bearing. This may be an easier find if true.
Old May 13, 2015 | 08:23 AM
All gas engine SBO cranks have the same stroke (3.385") and the same journal sizes. Balance will be different depending on piston and rod weights (403s have heavier pistons and beefier rods). Of course, all 1964-67 cranks are forged. Later SBO cranks are cast.
If you're pulling the crank out anyway, just have your original machined.
Old May 14, 2015 | 08:48 AM
rocket67's Avatar
Thanks again! What size hole would have to be machined in the end of the crank to fit the pilot bearing? If I decide to stay auto, would the TH350 bolt to the 330 block and would the flex plate have to be changed?
Old May 14, 2015 | 01:43 PM
Yes. This is a very common and very easy swap. The biggest issue is connecting the kickdown cable.
Nope.
Old May 15, 2015 | 07:34 AM
rocket67's Avatar
Thanks Joe and everyone else. Joe, I see you are located in Va, also. I live below Richmond.
Old May 15, 2015 | 09:10 PM
Cool. I'm in Lovettsville, in NoVA. I'm about as far north as you can get in the state of VA.
Old May 16, 2015 | 06:13 PM
rocket67's Avatar
Question for Joe
Joe, is there someone in our area who is is a good source for 66-67 cutlass parts. Among other items, I need a bell housing, flywheel and clutch parts. Thanks for all your replies.
