65 Drop Top
Old Aug 17, 2009 | 03:35 PM
65dynamic88conv's Avatar
65 Drop Top
I'm a mechanic and just bought a 1965 Dynamic 88 convertible. It's alittle soft but thats OK, I got it cheap and my wife loves it. The speedometer cable just broke. This one seems hard to find (goes to the LF hub). Any help on where I could find one?
Old Aug 17, 2009 | 04:06 PM
Power top motor
The power top also goes down fine but doesnt have the nuts to go up. How do I check the fluid? I don't see a reservoir, is there a plug on the motor to fill?
Old Aug 17, 2009 | 05:39 PM
citcapp's Avatar
Welcome to CO
Try http://www.fusick.com/ for the cable. Sorry I can't help you with your top. someone will chime in
Old Aug 17, 2009 | 07:55 PM
I tried them, they didn't have it. Is it that rare?
Old Aug 17, 2009 | 08:38 PM
bigoldscruiser's Avatar
2 '66 98's
The reservoir is part of the motor assembly. There is either a metal screw in plug or a rubber plug on the end of the unit. You can tell if the fluid is low by looking at the lines to the cylinders as you are operating the system. Large air bubbles will tell the tale. Just don't overfill the system.
Where are you located?? I have a nice used speedo cable removed from a 45,000 mile car when Cruise Control was added. I am in New Jersey. Bruce
Old Aug 18, 2009 | 04:30 AM
Oldsguy's Avatar
Past Administrator
My '69 Delta had the same speedo cable set up, it had the cable and the hub cover but I know the covers are sometimes hard to find. Never thought about what I would do if the cable broke. Welcome to CO and hope you find one.
Old Aug 18, 2009 | 05:09 AM
My cable broke right in the middle, hub cover is OK. I had to cut it near the spindle so I could unscrew it. It felt like it had never been taken apart. I'm located in wisconsin.
Let me know what you want for the cable.
Whats the procedure to fill the motor to prevent overfilling?
Old Aug 18, 2009 | 04:07 PM
old blue's Avatar
Smile hey
Hey just pop the plug out and fill you will want to bleed the lines just like you do brake lines easy to acess from the rear just remove the screws behind the back seat
Old Aug 18, 2009 | 05:58 PM
Oldsmobomb's Avatar
convertible top fill & bleed
There are several good filling procedure guides available at the vendor sites. I like the one from Hydro-E-lectric (www.hydroe.com) if the system is empty, or new ram cylinders have been installed. It is located under "Tips" at their website.
If the system is merely low, I have used this procedure very successfully on my '66 Cutlass. It will properly replenish the fluid level and purge the system of air. Start with the top UP.
1) find the fill plug on the reservoir end of the motor ( in the trunk ) and remove it. It may be threaded in or a rubber plug. Have a rag handy, even though nothing may come out.
2) using a length of tubing (20"-30" give or take) with a diameter that tightly fits into the plug opening, place one end snugly 1/2"-1" into the opening, and the other into a container of the appropriate fluid - below the fluid level - you do not want to suck air at any time.
3) operate the top up and down thru several cycles, using a helper if necessary to raise the top. If you hear lots of whining and gurgling from the pump, you have air in the system, and it will eventually purge or bubble out into the container of topping up fluid. You do not want a lid on the topping up container - just don't dump it over.
So, tight fit at the plug opening, loose fit at the container end. Watch the level in the topping up container and don't let it run out - ie., don't suck air. Absent any leaks in the system, operating the top up and down will purge the air out, draw fluid in to replace the air, the sound level will become quieter, and there will be less gurgling. This may take 2 cycles, or 6 cycles. Just listen and use judgement. Take your time, and don't overheat the pump motor. You should probably have the car outdoors and running to make sure you have a full 12+ volts to the motor. You can stop and rest at any point as long as the top is full up or full down - do NOT remove the tubing until finished (next step).
4) IMPORTANT !!! When you believe your system is bled sufficiently, LOWER the top to the full DOWN position. Have the plug and a rag ready, remove the tightly fitting filling hose, and insert the plug. Move right along, but there should be very little leakage. The location of the fill hole is set up to allow an air space to remain in the reservoir. The reservoir must not be overfilled to prevent blowing seals or fittings. Ending this process with the top DOWN is the correct procedure.
5) Once the plug is back in, you can operate the top at will. It should be properly filled, and free of excess air.
I do not know what fluid is in your system - but whatever it is - stay with the same ! Some systems used non-silicone brake fluid, some used trans fluid, some used hydraulic oil (like jack oil). They all smell and look different, you should make sure which you have before adding any !
For my '66 Cutlass, it was auto trans fluid (Dexron).
Old Aug 19, 2009 | 07:44 AM
I'll give this a try as soon I can pry the car away from my wife! The top has been down for over a month now, but sooner or later she will judge the weather wrong and will need to put it up on her own.
Thanks!
Old Aug 19, 2009 | 09:18 AM
Kanter might have a speedo cable for your car. Also try Rock Auto.
Old Aug 19, 2009 | 09:34 AM
cfair's Avatar
Power Top servicing
The power top goes up/down using a hydraulic motor located behind the rear seat. You'll see a big cut out in the metal wall that's behind the seat. If you have a top well cover (originally canvas) the motor's beneath it. Otherwise, you'll probably just see it by looking down in top well.
The motor's held in by a set of three rubber bushings - giant cylindrical things. The just pull free if you still have yours in there. If not, it could be held in place by most anything. I've used zip ties as necessary. Anyway, there are 2 sets of hydraulic lines - one for upward movement, one for down. These are the white plastic lines with very soft brass fittings on the end. They're expensive to replace so remove them softly & slowly.
The electrical connector is just a generic two wire affair, but it's big guage - maybe 10 or so since the motor draws heavy amps. I think there's probably a ground too, but I can't remember.
Your goal is to refill the top motor's fluid reservoir. It's usually filled with either brake fluid or ATF. Basically do a flush/fill process like you would for bleeding brakes and you're done. This involves a long vacuum hose, a big jar filled with the right fluid (don't mix) and running the top up & down a bunch of times until you have no more bubbles in the system. Then put the rubber plug back in the reservoir and things should be fine.
1970cs
Nov 19, 2012 05:20 PM
Jamesbo
Apr 15, 2010 10:21 AM
Jamesbo
Nov 12, 2009 05:56 AM
woodie582
Jul 21, 2008 05:53 AM
