'60 Dynamic 88 Carburetor question
Old May 27, 2017 | 11:59 PM
6262's Avatar
Hello,
I am Nils from Germany. Although I am always fond of Oldsmobiles I own a 1962 Cadillac convertible for myself.
I registered here on behalf of a friend who has a 1960 Oldsmobile Dynamic 88 sedan but no affection to the digital world.
He has the following problem:
The 2bbl Rochester on his is engine is creating difficulties constantly.
We have not found an overhaul kit yet. An alternative would be the switch to a 4bbl carburetor , but we do not know which manifolds interchange to the original '60 371 engine.
So, my question is,
a) are there overhaul kits for a '60 Rochester 2bbl carburetor
b) is there a manifold for a 4bbl carburetor which fits the '60 371?
Thanks in advance,
Nils
Old May 28, 2017 | 12:13 AM
Charlie Jones's Avatar
Phantom Phixer
Rock Auto . com has carb. kits for about $15
http://www.rockauto.com/en/catalog/o...epair+kit,5964
Old May 28, 2017 | 06:55 AM
Tedd Thompson's Avatar
Or try this place https://quadrajetparts.com/accelerat...c-104_109.html What you are looking fore is a kit for a Rochester 2gc. There should be plenty to chose from it's a pretty common carb in the states. Hopefully there is still a copper tag with a number on one corner of the carb body that will help identify which 2gc it is,there were many..... Tedd
Old May 29, 2017 | 01:17 AM
6262's Avatar
Thanks a lot! Great help.
Now he has to make the decision if he wants to overhaul it or change over to a 4bbl.
Would the 394 intake manifold for the 4bbl carburetor fit the 371? If yes, which years do interchange?
Old May 29, 2017 | 07:05 AM
59-59-59's Avatar
Any 1959-1964 371/394 will fit
Old May 29, 2017 | 07:26 AM
As stated above 59 and later 371/394 will work but also keep in mind that any you will find will be 50 years old and probably the carb will need to be rebuilt also. The carb you would need for the new intake will be the Rochester 4gc. Different new carbs are available but not Rochester and linkage will need to made to adapt to that car. Very doable but not a plug and play thing... Tedd
Old May 31, 2017 | 07:41 AM
6262's Avatar
Thanks for the great advice.
I agree with you. He has a nice survior in Golden Mist but constant trouble with the original carburetor.
I am trying to convince him to keep the original carb and not to switch to an Edelbrock carb or the like.
Old May 31, 2017 | 11:13 AM
Phantom Phixer
He has a nice survior .......
X2 here .
While an Edelbrock carb will bolt up to the stock Olds four barrel manifold .
It will take a degree from the McGuyver school of engineering to design and build the proper throttle linkage so that the transmission will shift properly .
Also , the Ebelbrock was designed with high performance in mind .
Switching to it will probably cause a drop in already bad fuel mileage .
jmills
Mar 23, 2014 01:34 PM
AirborneRME
Jul 10, 2013 01:08 PM
Playerdark
Jan 25, 2013 02:19 PM
1971CutlassSupreme
Jul 5, 2011 04:20 PM
yeahbuddy
Jun 1, 2010 05:38 AM
