52 olds 303 v8
Old Dec 26, 2012 | 09:26 AM
jmills's Avatar
52 olds 303 v8
i need do some rework on my engine mainly front and rear oil seals i have learned that i can use a rear seal from a 460 ford eng. but what do i use for the front seal ?
Old Dec 26, 2012 | 10:48 AM
citcapp's Avatar
Actually the ford 460 rear main only works on a 455. You can however use a
Victor JV-604 (Actually a Mopar #).
Old Dec 27, 2012 | 01:55 PM
jmills's Avatar
'52 Olds front main oil seal
Thanks for the info on the rear seal. Do you know what I'd need for replacing the front seal???
Old Dec 27, 2012 | 01:59 PM
jmills's Avatar
Thanks for the info regarding rear seal replacement. Would you know what I need to replace the front main oil seal???
Old Dec 27, 2012 | 06:42 PM
citcapp's Avatar
As far as I can tell the front seal is part of the timing cover gasket set and not a separate part, This set is available thru Rock Atuo.
http://www.rockauto.com/catalog/x,ca...2BWheel%2BSeal
bobbyb
Dec 7, 2009 04:11 PM
cowboy76
Jan 23, 2009 08:33 AM
Nailhead 88
Oct 7, 2008 02:02 PM
Nailhead 88
Jul 29, 2008 11:42 AM
cowboy76
Jul 5, 2006 09:03 AM
