455 torker intake
455 torker intake
Hi everyone j want to knw if the rochester quadrajet woul work good with the 455 torker i take on my 1968 442 with the 455 motor?? Any suggestions or tips i want more torque on my 4-4-2
Nothing yet we just got it running two days ago but the carb is not working good it appears to be stock or too old im guuna have it rebuild but i bought a torker intake and i was wondering ifi the quadrajet woul fit and work fine with it.. What you guys recommend should i live it stock and just rebuilt the carb or buy a new carb?? Its a 68 442..
The Torker is made for a quadrajet. I would have it rebuilt, and I know the perfect guy to do it. His name is Danny Sarvis, he's in San Antonio. For what he does and how well it will run after he's done, you can't beat the price. I'll pm you his information if you're interested.
Steve
Steve
That's the problem, you haven't changed anything else with the engine. Just adding the intake manifold and rebuilding the carburetor may not necessarily give you more power than stock, but it will give you more power than you have right now since it's not running properly.
You have a '68 442 with a 455...what heads are on it? Do you know anything else about the engine?
Well, I'll send you Danny's information and he can rebuild the Q-Jet. That'll make it run a ton better than it does now. Then if you want to add other stuff later on at least it will handle whatever you throw at it Check your pm
Steve
Steve
I would go with the electic one if it was me. But then Im not steve so you didnt ask me . You can block the cross over and gain power and that way and you dont have to find or work with old linkage and parts to make it work with the intake.
I'll send you his info and you can ask him...or take FFG's advice. Check your PM.
Steve
What exactly is this crossover you're speaking of im a beginner lol. im learning off of these damn forums and books i've been reading
The crossover is where the heat will come up and run the choke . If you block it you get a cooler intake or so the that is the reason ?? if it is a real deal or another speed trip . You can get gaskets with plates to block them or some will melt pistions to fill the void , or slugs can be fit to block it at the intake and head and intake .
http://www.youtube.com/watch?v=uvoE1RTrAFw
I see you have Bill Travatos book that has lots of good info in it google BTR olds builds or go to V8tv and see he has a 9 or 10 group of how toos on a olds build up I will see if I can find it and link it.
Well i saw a big E on one of the heads but am not planning to rebuild the motor yet maybe next summer i just want it to run good for now im replacing the water pump,fuel pump,tyming chain and should i replace the cam and lifters what you guys think???
Maybe a couple suggestions. From experience, a dual plane intake like the Edelbrock Performer, makes a lot more low end torque than a single plane. Don't think I'd use a Torker on a stock engine. Also, Q-Jets are excellant carbs, when properly set up for your engine/gearing combination. This can be a problem, when sending out the carb for your present stock set up, only having to do it again later, when changing cam, heads and exhaust later on. If you mention this to the carb builder, will likely give you break on later tuning. Lars Grimsrud and Cliff's Performance, are also very good with Q-Jets. Contact Lars v8fastcars@msn.com, and he'll send you his tuning papers at no charge, telling all about Q-Jets. Lots of good information here.
Ok i get it .. So im replacing the the intake snf had the carb rebuild already what else would you suggest to replace how bout the timin chain and fuel pump and what would i get if i replace the camshaft and lifters..? Oh and does my 68 4-4-2 suppose to have a posi rear end.. Sorry but its my first muscle car..
Your car should have posi but that's not to say someone didn't change it out during it's lifetime.
Well the heads are from a 1970 engine. The block you would need the vin derivative off the flat spot on the front left corner of the engine to know. Either way, it won't really give you an accurate horsepower number...especially if the engine had been rebuilt previously.
svnt442
July 17th, 2011 04:43 PM
