455
Old Jun 23, 2014 | 05:06 PM
ironlou's Avatar
455
Can a 455 fit in a 66 cutlass conv?
Old Jun 23, 2014 | 05:19 PM
tru-blue 442's Avatar
Old School Olds
Yes, with some work.
What is in there now?
Old Jun 23, 2014 | 05:51 PM
Yes. A 66 442, which is essentially the same car, came with a BBO 400 engine.
Old Jun 23, 2014 | 06:11 PM
Actually, very little work if the car currently has a 330 V8. As noted, the 455 is externally identical to the 400 that was available in the 1966 442. The 455 bolts to the existing motor mounts and trans. You will need a flexplate that matches the 455, as Olds changed the crank flange bolt pattern for the 1968-1990 engines. Use the W/Z exhaust manifolds from a 1969-1972 442. Get a radiator for a 1966 442, which will be larger than your 330 radiator. That's about it.
dp442
Feb 15, 2011 04:22 PM
sx455raidercelticfan
Nov 23, 2010 05:45 AM
SKINNY IL
May 14, 2010 07:12 AM
egknz
Jul 21, 2009 01:09 PM
