394 Holiday Dynamic engine mounts
FRONT MOTOR MOUNT OR RIGHT AND LEFT TRANSMISSION MOUNTS ?
TRANSMISSION MOUNTS ARE PART #s A2216 AND A2217 .
THIS IS THE PLACE I BOUGHT MINE MAC AUTO PARTS PH# 914-939-0303 ABOUT $50.00 FOR BOTH INC FREIGHT. HOPE THIS HELPS.
TOM
TOM
Sounds like you're confused about how the engine mounts. I think you're also realising that a modern chain auto parts store is not going to stock or be able to get anything like this.
You have:
Front engine mount- between timing cover and front frame crossmember. This is the rectangular one in the Fusick pic.
Transmission mounts- one on each side at joint between engine and transmission. These are the triangular shaped ones in the Fusick pic. They bolt to the transmission housing and to the rear crossmember and are left and right side.
There is no rear transmission mount.
You have:
Sorry guys I havent been on in a while.Yep just standard tranny mounts. I have since rebuilt the front end and had a super hard time finding upper c-arm bushings.I found mobileparts in New York with NOS bushings amazing right? This car has a bunch of one year only parts. Lower c-arm is also available in the 64 and that it. Car is driving great. I would now like to swith from a 2bbl to a 4bbl. Any ideas on manifolds and how hard is it to match tranny linkage to a aftermarket carb or do I need to stick with olds gear?
I just changed the motor and trans mounts on my 63, got them all from Fusick's and they fit perfectly. Regarding the manifold/carb swap, stay with stock parts and make sure you have all the trans linkage adjusted properly. The Slim Jim is extremely sensitive in this area and you don't want to screw it up. Good luck!
joesw31
May 31st, 2015 04:17 PM
63 Holidayscottikus
March 13th, 2011 06:38 AM
